Problem in issuing SSL
HR
Hamza Rauf #1
I’m facing an issue with hostname SSL since I upgraded to the latest version. (Everything works fine before)
The same issue exists for other domains also. Here are some server logs.
Domains are http://verticalcloud.co and http://lilpaw.shop
[10.15.2022_00-00-04] Checking SSL for portal.keephiring.net.
[10.15.2022_00-00-04] SSL exists for portal.keephiring.net. Checking if SSL will expire in 15 days..
[10.15.2022_00-00-04] SSL exists for portal.keephiring.net and is not ready to renew, skipping..
[10.15.2022_00-00-04] Checking SSL for dial.1477.store.
[10.15.2022_00-00-04] SSL exists for dial.1477.store. Checking if SSL will expire in 15 days..
[10.15.2022_00-00-04] SSL exists for dial.1477.store and is not ready to renew, skipping..
[10.15.2022_00-00-04] Checking SSL for sms.easybill.shop.
[10.15.2022_00-00-04] SSL exists for sms.easybill.shop. Checking if SSL will expire in 15 days..
[10.15.2022_00-00-04] SSL exists for sms.easybill.shop and is not ready to renew, skipping..
[10.15.2022_02-54-02] 'list' object has no attribute 'find'
[10.15.2022_02-56-24] 'list' object has no attribute 'find'
[10.15.2022_02-57-41] Request body exceeded settings.DATA_UPLOAD_MAX_MEMORY_SIZE.
[10.15.2022_02-57-53] 'list' object has no attribute 'find'
[10.15.2022_03-10-28] Status Code: Unknown for: http://www.lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-10-28] Status Code: Unkown for: http://lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-10-35] /root/.acme.sh/acme.sh --issue -d lilpaw.shop -d www.lilpaw.shop --cert-file /etc/letsencrypt/live/lilpaw.shop/cert.pem --key-file /etc/letsencrypt/live/lilpaw.shop/privkey.pem --fullchain-file /etc/letsencrypt/live/lilpaw.shop/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_03-10-43] Failed to obtain SSL for: lilpaw.shop and: www.lilpaw.shop
[10.15.2022_03-10-43] Trying to obtain SSL for: lilpaw.shop
[10.15.2022_03-10-49] Failed to obtain SSL, issuing self-signed SSL for: lilpaw.shop
[10.15.2022_03-10-49] Self signed SSL issued for lilpaw.shop.
[10.15.2022_03-16-28] Status Code: Unknown for: http://www.lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-16-28] Status Code: Unkown for: http://lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-16-39] /root/.acme.sh/acme.sh --issue -d lilpaw.shop -d www.lilpaw.shop --cert-file /etc/letsencrypt/live/lilpaw.shop/cert.pem --key-file /etc/letsencrypt/live/lilpaw.shop/privkey.pem --fullchain-file /etc/letsencrypt/live/lilpaw.shop/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_03-16-46] Failed to obtain SSL for: lilpaw.shop and: www.lilpaw.shop
[10.15.2022_03-16-46] Trying to obtain SSL for: lilpaw.shop
[10.15.2022_03-16-52] Failed to obtain SSL, issuing self-signed SSL for: lilpaw.shop
[10.15.2022_03-16-53] Self signed SSL issued for lilpaw.shop.
[10.15.2022_03-23-49] Status Code: Unknown for: http://www.lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-23-49] Status Code: Unkown for: http://lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-23-56] /root/.acme.sh/acme.sh --issue -d lilpaw.shop -d www.lilpaw.shop --cert-file /etc/letsencrypt/live/lilpaw.shop/cert.pem --key-file /etc/letsencrypt/live/lilpaw.shop/privkey.pem --fullchain-file /etc/letsencrypt/live/lilpaw.shop/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_03-24-04] Failed to obtain SSL for: lilpaw.shop and: www.lilpaw.shop
[10.15.2022_03-24-04] Trying to obtain SSL for: lilpaw.shop
[10.15.2022_03-24-06] Failed to obtain SSL, issuing self-signed SSL for: lilpaw.shop
[10.15.2022_03-24-07] Self signed SSL issued for lilpaw.shop.
[10.15.2022_03-25-05] Status Code: Unknown for: http://www.verticalcloud.co/.well-known/acme-challenge/verticalcloud.co. Error: Exceeded 30 redirects.
[10.15.2022_03-25-06] Status Code: Unkown for: http://verticalcloud.co/.well-known/acme-challenge/verticalcloud.co. Error: Exceeded 30 redirects.
[10.15.2022_03-25-18] /root/.acme.sh/acme.sh --issue -d verticalcloud.co -d www.verticalcloud.co --cert-file /etc/letsencrypt/live/verticalcloud.co/cert.pem --key-file /etc/letsencrypt/live/verticalcloud.co/privkey.pem --fullchain-file /etc/letsencrypt/live/verticalcloud.co/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_03-25-25] Failed to obtain SSL for: verticalcloud.co and: www.verticalcloud.co
[10.15.2022_03-25-25] Trying to obtain SSL for: verticalcloud.co
[10.15.2022_03-25-32] Failed to obtain SSL, issuing self-signed SSL for: verticalcloud.co
[10.15.2022_03-25-32] {'email@verticalcloud.co': (550, b'5.1.1 <email@verticalcloud.co>: Recipient address rejected: User unknown in virtual mailbox table')}
[10.15.2022_03-25-32] Self signed SSL issued for verticalcloud.co.
[10.15.2022_03-33-09] Status Code: Unknown for: http://www.verticalcloud.co/.well-known/acme-challenge/verticalcloud.co. Error: Exceeded 30 redirects.
[10.15.2022_03-33-09] Status Code: Unkown for: http://verticalcloud.co/.well-known/acme-challenge/verticalcloud.co. Error: Exceeded 30 redirects.
[10.15.2022_03-33-14] /root/.acme.sh/acme.sh --issue -d verticalcloud.co -d www.verticalcloud.co --cert-file /etc/letsencrypt/live/verticalcloud.co/cert.pem --key-file /etc/letsencrypt/live/verticalcloud.co/privkey.pem --fullchain-file /etc/letsencrypt/live/verticalcloud.co/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_03-33-22] Failed to obtain SSL for: verticalcloud.co and: www.verticalcloud.co
[10.15.2022_03-33-22] Trying to obtain SSL for: verticalcloud.co
[10.15.2022_03-33-28] Failed to obtain SSL, issuing self-signed SSL for: verticalcloud.co
[10.15.2022_03-33-28] {'email@verticalcloud.co': (550, b'5.1.1 <email@verticalcloud.co>: Recipient address rejected: User unknown in virtual mailbox table')}
[10.15.2022_03-33-28] Self signed SSL issued for verticalcloud.co.
As far as my understanding, there is no problem with DNS or NS because everything worked fine before. Also, for some domains, SSL is working fine.
jo
josephgodwinke #2
From this line:
This email address email@verticalcloud.co does not exist on your list of mailboxes. I have also tried to trace that email address with a renowned webtool and it states the email is non-existent. Create that email address and try again.
HR
Hamza Rauf #3
Thanks for the reply, Anyhow, I’ve created this email@domain.com for both domains, but the issue still remains.
[10.15.2022_22-01-08] [Errno 2] No such file or directory: '/home/cyberpanel/git'. [IncScheduler.git:90]
[10.15.2022_23-37-13] Status Code: Unknown for: http://www.verticalcloud.co/.well-known/acme-challenge/verticalcloud.co. Error: Exceeded 30 redirects.
[10.15.2022_23-37-13] Status Code: Unkown for: http://verticalcloud.co/.well-known/acme-challenge/verticalcloud.co. Error: Exceeded 30 redirects.
[10.15.2022_23-37-14] /root/.acme.sh/acme.sh --issue -d verticalcloud.co -d www.verticalcloud.co --cert-file /etc/letsencrypt/live/verticalcloud.co/cert.pem --key-file /etc/letsencrypt/live/verticalcloud.co/privkey.pem --fullchain-file /etc/letsencrypt/live/verticalcloud.co/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_23-37-22] Failed to obtain SSL for: verticalcloud.co and: www.verticalcloud.co
[10.15.2022_23-37-22] Trying to obtain SSL for: verticalcloud.co
[10.15.2022_23-37-29] Failed to obtain SSL, issuing self-signed SSL for: verticalcloud.co
[10.15.2022_23-37-29] Self signed SSL issued for verticalcloud.co.
[10.15.2022_23-39-38] Status Code: Unknown for: http://www.lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_23-39-38] Status Code: Unkown for: http://lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_23-39-39] /root/.acme.sh/acme.sh --issue -d lilpaw.shop -d www.lilpaw.shop --cert-file /etc/letsencrypt/live/lilpaw.shop/cert.pem --key-file /etc/letsencrypt/live/lilpaw.shop/privkey.pem --fullchain-file /etc/letsencrypt/live/lilpaw.shop/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_23-39-50] Failed to obtain SSL for: lilpaw.shop and: www.lilpaw.shop
[10.15.2022_23-39-50] Trying to obtain SSL for: lilpaw.shop
[10.15.2022_23-39-56] Failed to obtain SSL, issuing self-signed SSL for: lilpaw.shop
[10.15.2022_23-39-57] Self signed SSL issued for lilpaw.shop.
jo
josephgodwinke #4
Access this page https://URL:8090/manageSSL/manageSSL and issue the SSL certificate for specific domains one by one. This will reissue the certificates. At the same time tail /home/cyberpanel/error-logs.txt in terminal as you do this
MA
Malik Aamir Ali #5
bash: /home/cyberpanel/error-logs.txt: Permission denied
jo
josephgodwinke #6
Access your SSH account using sudo user
MA
Malik Aamir Ali #7
]$ /home/cyberpanel/error-logs.txt
same issue
jo
josephgodwinke #8
Run chown -R root: /home/cyberpanel/error-logs.txt
MA
Malik Aamir Ali #9
]# -R root: /home/cyberpanel/error-logs.txt
bash: -R: command not found
]$ -R root: /home/cyberpanel/error-logs.txt
Dear Thank for help but still same issue
jo
josephgodwinke #10
Kindly run the command as posted chown -R root: /home/cyberpanel/error-logs.txt
MA
Malik Aamir Ali #11
]$ -R root: /home/cyberpanel/error-logs.txt bash: -R: command not found
r]# -R root: /home/cyberpanel/error-logs.txt bash: -R: command not found
jo
josephgodwinke #12
Paste what you see below this line into your terminal:
systemctl restart lscpd && chown -R root: /home/cyberpanel/error-logs.txt
MA
Malik Aamir Ali #13
==== AUTHENTICATION COMPLETE ===
chown: missing operand
Try ‘chown --help’ for more information.
jo
josephgodwinke #14
systemctl restart lscpd && chown -R  root:root /home/cyberpanel/error-logs.txt
chown [OPTION]… [OWNER][:[GROUP]] FILE…
MA
Malik Aamir Ali #15
Solution
thank so much Dear done issue fixed
MA
Malik Aamir Ali #16
Solution
