thowsenmedia #1
Issuing SSL works fine for the cyberpanel site itself, but for other sites I cannot issue SSL.
Running acme.sh in terminal shows it fails to verify.
I think the issue is that its placing the token in the wrong directory because I’ve changed the web root via VHost config from /home/user/mysite.com to /home/user/mysite.com/public
How can I make cyberpanel aware of this change?
edit
I tried the solution posted at SSL and vHost relationship - #2 by AnAlien but it didn’t work either.
edit 2
I got the above solution to “work”, in that I can access mysite.com/.well-known. I had to modify a .htaccess file in mysite.com/public_html/web (the web root).
Still get invalid response though when running acme.sh from terminal :\
edit 3
Looks like the command I was typing was incorrect. One of the arguments is the directory to save to token to - after putting /home/mysite/public_html - I got success - however, when accessing the site via chrome - it still shows up as not safe somehow :\
  • Thanks in advance.
