Problem All website on cyberpanel
ho
hosteko #1
hello, I’m having problems with ssl in cyberpanel.
in the error log it exits like this:
[07.21.2022_00-59-26] Status Code: Unkown for: http://www.ayojambi.id/.well-known/acme-challenge/ayojambi.id. Error: HTTPConnectionPool(host=‘www.ayojambi.id’, port=80): Max retries exceeded with url: /.well-known/acme-challenge/ayojambi.id (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0x7fc9042b99e8>: Failed to establish a new connection: [Errno -2] Name or service not known’,))
[07.21.2022_00-59-27] Status Code: Unkown for: http://ayojambi.id/.well-known/acme-challenge/ayojambi.id. Error: HTTPConnectionPool(host=‘ayojambi.id’, port=80): Max retries exceeded with url: /.well-known/acme-challenge/ayojambi.id (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0x7fc9042b9240>: Failed to establish a new connection: [Errno -2] Name or service not known’,))
[07.21.2022_00-59-29] /root/.acme.sh/acme.sh --issue -d ayojambi.id -d www.ayojambi.id --cert-file /etc/letsencrypt/live/ayojambi.id/cert.pem --key-file /etc/letsencrypt/live/ayojambi.id/privkey.pem --fullchain-file /etc/letsencrypt/live/ayojambi.id/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[07.21.2022_00-59-29] Failed to obtain SSL for: ayojambi.id and: www.ayojambi.id
[07.21.2022_00-59-29] /root/.acme.sh/acme.sh --issue -d ayojambi.id --cert-file /etc/letsencrypt/live/ayojambi.id/cert.pem --key-file /etc/letsencrypt/live/ayojambi.id/privkey.pem --fullchain-file /etc/letsencrypt/live/ayojambi.id/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[07.21.2022_00-59-29] Failed to obtain SSL, issuing self-signed SSL for: ayojambi.id
[07.21.2022_00-59-29] Self signed SSL issued for ayojambi.id.
can help me?
MK
Mirza Khadnezar S [sick] #2
@tmoore : bro… can you help him ? he is my best friends from ID …
i recommended him to use cyberpanel lol
tb
tbaldur #3
Still at work, will send a message in about 3hours
sh
shoaibkk #4
Run this command from terminal and show out put
ho
hosteko #6
[Thu Jul 21 20:49:20 +08 2022] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Thu Jul 21 20:49:20 +08 2022] Creating domain key
[Thu Jul 21 20:49:20 +08 2022] The domain key is here: /root/.acme.sh/ayojambi.id_ecc/ayojambi.id.key
[Thu Jul 21 20:49:20 +08 2022] Multi domain=‘DNS:ayojambi.id,DNS:www.ayojambi.id’
[Thu Jul 21 20:49:20 +08 2022] Getting domain auth token for each domain
[Thu Jul 21 20:49:23 +08 2022] Getting webroot for domain=‘ayojambi.id’
[Thu Jul 21 20:49:23 +08 2022] Getting webroot for domain=‘www.ayojambi.id’
[Thu Jul 21 20:49:24 +08 2022] ayojambi.id is already verified, skip http-01.
[Thu Jul 21 20:49:24 +08 2022] www.ayojambi.id is already verified, skip http-01.
[Thu Jul 21 20:49:24 +08 2022] Verify finished, start to sign.
[Thu Jul 21 20:49:24 +08 2022] Lets finalize the order.
[Thu Jul 21 20:49:24 +08 2022] Le_OrderFinalize=‘https://acme-v02.api.letsencrypt.org/acme/finalize/639643766/108793476546’
[Thu Jul 21 20:49:25 +08 2022] Downloading cert.
[Thu Jul 21 20:49:25 +08 2022] Le_LinkCert=‘https://acme-v02.api.letsencrypt.org/acme/cert/0353c141d67d0fc83675093b609cc912aef3’
[Thu Jul 21 20:49:26 +08 2022] Cert success.
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
[Thu Jul 21 20:49:26 +08 2022] Your cert is in: /root/.acme.sh/ayojambi.id_ecc/ayojambi.id.cer
[Thu Jul 21 20:49:26 +08 2022] Your cert key is in: /root/.acme.sh/ayojambi.id_ecc/ayojambi.id.key
[Thu Jul 21 20:49:26 +08 2022] The intermediate CA cert is in: /root/.acme.sh/ayojambi.id_ecc/ca.cer
[Thu Jul 21 20:49:26 +08 2022] And the full chain certs is there: /root/.acme.sh/ayojambi.id_ecc/fullchain.cer
[Thu Jul 21 20:49:26 +08 2022] Installing cert to: /etc/letsencrypt/live/ayojambi.id/cert.pem
[Thu Jul 21 20:49:26 +08 2022] Installing key to: /etc/letsencrypt/live/ayojambi.id/privkey.pem
[Thu Jul 21 20:49:26 +08 2022] Installing full chain to: /etc/letsencrypt/live/ayojambi.id/fullchain.pem
ho
hosteko #7
I have replied to your message
ho
hosteko #8
thanks you All for help, i run:
and run
service lsws restart
problem solved.
