Ssl not work Is there a solution?
lM
leader_Me #1
The ssl certificate used to be issued and works now it does not work and gives duration Your SSL will expire in 3649 days.
Is there a solution to this problem?
I want to issue a free certificate
Dr
Dreamer #3
Check DNS records and if use cloudflare try turning proxy cloud gray.
lM
leader_Me #4
I do not use cloudflare Is there a solution?
sh
shoaibkk #5
Your cyberpanel is up to date and also share the vhost configuration with me.
lM
leader_Me #6
Yes, the board has been updated
What do I do in vhost
