ModSecurity on CyberPanel Problem Stripe hooks
RU
RO3B UN1X #1
Hi Guys, My website use to work normally after I followed the instruction to enable and install ModSecurity.
if any of my customers want to pay using stripe after payment when he clicks on return to the merchant they will have ‘‘403 Forbbiden error’’ and their balance will not be updated.
And in the same time, I can’t deactivate the security. How can I fix this problem ??
The URL like this would be blocked by the ModSecurity:
https://example.com/add_funds/stripe3ds/complete?session_id=cs_live_a14EHSM5SIWbb5DhvF&paymentOption=stripe3ds&orderId=ORDS165271
Please help & Thank you
Dr
Dreamer #2
See from logs which rule block that and disable it.
of
ofm1990 #3
I have the same problem, how did you solve it? @RO3B ?
RM
Rana Muhammad Usman Nasir #4
Can you check that which rule is blocking this request and disable that specific rule.
of
ofm1990 #6
Thanks!
Wouldn’t it be possible to disable it by adding a rule?
From what I understand the only way is to identify the package and disable the item completely, right?
I’ve tried and it doesn’t work to add a rule like this for example:
SecRule REQUEST_URI "@contains landingpages" "id:1001,phase:1,t:none,pass, nolog,ctl:ruleRemoveById=943120",
it would not be ideal to disable one of these items as the false positive is only in a URL.
thx
of
ofm1990 #7
It only worked when I went to the file and deleted line 79:
usr/local/lsws/conf/modsec/owasp-modsecurity-crs-3.0-master/rules/REQUEST-943-APPLICATION-ATTACK-SESSION-FIXATION.conf
It doesn’t work if you add the rules via cyberpanel
Dr
Dreamer #8
When you update cyberpanel your edit will be overwritten. You can go on cyberpanel modsecurity settings and disable rule 943.
of
ofm1990 #9
I did that, it really works, but shouldn’t the rules work?
I would like to disable 943 just for the specific URL, so all my other 20 sites are vulnerable to these attacks because of a single URL.
of
ofm1990 #10
This ticket continues here:
