OpenLiteSpeed won't start after changing ssl
pr
presidas #1
Hey! I had an issue and accidently removed all SSL certificates. Now OpenLiteSpeed won’t start. I’ve tried restarting it, but it keeps returning error. Any ideas?
Error log here:
2022-04-11 15:58:03.136260 [INFO] [735959] Add QUIC.cloud IPs from admin/conf/quic-cloud-ips to trusted ACL ...
2022-04-11 15:58:03.136329 [INFO] [735959] Add CloudFlare Subnets to trusted ACL ...
2022-04-11 15:58:03.136384 [INFO] [735959] [PlainConf] [adminConfig:] start parsing file /usr/local/lsws/admin/conf/admin_config.conf
2022-04-11 15:58:03.136563 [INFO] [735959] [PlainConf] [adminConfig:] Finished parsing file /usr/local/lsws/admin/conf/admin_config.conf
2022-04-11 15:58:03.136956 [INFO] [735959] QuicEngine::init(), pid: 735959, log level [warn].
2022-04-11 15:58:03.137293 [INFO] [735959] [Module: modcompress 1.1] has been initialized successfully
2022-04-11 15:58:03.137407 [INFO] [735959] [Module: moddecompress 1.1] has been initialized successfully
2022-04-11 15:58:03.137484 [INFO] [735959] [Module: cache 1.64] has been initialized successfully
2022-04-11 15:58:03.138213 [ERROR] [735959] [SSL:0x2bb89b0] Config SSL Context with Certificate File: /usr/local/lsws/admin/conf/webadmin.crt and Key File:/usr/local/lsws/admin/conf/webadmin.key get SSL error: error:0b000074:X.509 certificate routines:OPENSSL_internal:KEY_VALUES_MISMATCHerror:0b000074:X.509 certificate routines:OPENSSL_internal:KEY_VALUES_MISMATCH
2022-04-11 15:58:03.138224 [ERROR] [735959] [config:admin:listener:adminListener:ssl] failed to create new SSLContext for *:7080
2022-04-11 15:58:03.138229 [ERROR] [735959] [config:admin:listener] No listener is available for admin virtual host!
2022-04-11 15:58:03.138394 [ERROR] [735959] Fatal error in configuration, exit!
2022-04-11 15:58:07.162671 [INFO] [config:server:basics] httpdWorkers: 2, Num of Processors: 2
2022-04-11 15:58:07.162696 [INFO] [config:server:basics] enableLVE: 0
2022-04-11 15:58:07.162700 [INFO] [config:server:basics] bubbleWrap: 0, cmd: '(null)'
2022-04-11 15:58:07.167156 [INFO] [PlainConf] [httpServerConfig:] start parsing file /usr/local/lsws/conf/httpd_config.conf
2022-04-11 15:58:07.167171 [INFO] [PlainConf] [httpServerConfig:] Finished parsing file /usr/local/lsws/conf/httpd_config.conf
2022-04-11 15:58:07.167175 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [checkprivatecache 1]
2022-04-11 15:58:07.167178 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [checkpubliccache 1]
2022-04-11 15:58:07.167181 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [maxcacheobjsize 10000000]
2022-04-11 15:58:07.167184 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [maxstaleage 200]
2022-04-11 15:58:07.167187 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [qscache 1]
2022-04-11 15:58:07.167190 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [reqcookiecache 1]
2022-04-11 15:58:07.167192 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [respcookiecache 1]
2022-04-11 15:58:07.167195 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [ignorereqcachectrl 1]
2022-04-11 15:58:07.167198 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [ignorerespcachectrl 0]
2022-04-11 15:58:07.167200 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [enablecache 0]
2022-04-11 15:58:07.167203 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [expireinseconds 3600]
2022-04-11 15:58:07.167206 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [enableprivatecache 0]
2022-04-11 15:58:07.167208 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [privateexpireinseconds 3600]
2022-04-11 15:58:07.167213 [NOTICE] Loading LiteSpeed/1.7.15 Open (lsquic 3.0.4, modgzip 1.1, cache 1.64, mod_security 1.4) BUILD (built: Tue Feb 22 16:27:52 UTC 2022) ...
2022-04-11 15:58:07.167223 [NOTICE] Using [BoringSSL]
2022-04-11 15:58:07.167974 [NOTICE] [ADMIN] server socket: uds://usr/local/lsws/admin/tmp/admin.sock.7313, fd 6.
2022-04-11 15:58:07.168094 [NOTICE] [735980] chroot is disabled.
2022-04-11 15:58:07.168102 [INFO] [735980] old priority: 0, new priority: 0
2022-04-11 15:58:07.168195 [INFO] [735980] [config:server:basics2] For better obscurity, server version number is hidden in the response header.
2022-04-11 15:58:07.169192 [INFO] [735980] setuid is allowed in Ext Apps
2022-04-11 15:58:07.169385 [NOTICE] [735980] [PID: 735980]: forked cgid: 735983
2022-04-11 15:58:07.169500 [INFO] [735980] Add QUIC.cloud IPs from admin/conf/quic-cloud-ips to trusted ACL ...
2022-04-11 15:58:07.169572 [INFO] [735980] Add CloudFlare Subnets to trusted ACL ...
2022-04-11 15:58:07.169622 [INFO] [735980] [PlainConf] [adminConfig:] start parsing file /usr/local/lsws/admin/conf/admin_config.conf
2022-04-11 15:58:07.169814 [INFO] [735980] [PlainConf] [adminConfig:] Finished parsing file /usr/local/lsws/admin/conf/admin_config.conf
2022-04-11 15:58:07.172380 [INFO] [735980] QuicEngine::init(), pid: 735980, log level [warn].
2022-04-11 15:58:07.172725 [INFO] [735980] [Module: modcompress 1.1] has been initialized successfully
2022-04-11 15:58:07.172808 [INFO] [735980] [Module: moddecompress 1.1] has been initialized successfully
2022-04-11 15:58:07.172883 [INFO] [735980] [Module: cache 1.64] has been initialized successfully
2022-04-11 15:58:07.173568 [ERROR] [735980] [SSL:0xf8d9b0] Config SSL Context with Certificate File: /usr/local/lsws/admin/conf/webadmin.crt and Key File:/usr/local/lsws/admin/conf/webadmin.key get SSL error: error:0b000074:X.509 certificate routines:OPENSSL_internal:KEY_VALUES_MISMATCHerror:0b000074:X.509 certificate routines:OPENSSL_internal:KEY_VALUES_MISMATCH
2022-04-11 15:58:07.173582 [ERROR] [735980] [config:admin:listener:adminListener:ssl] failed to create new SSLContext for *:7080
2022-04-11 15:58:07.173586 [ERROR] [735980] [config:admin:listener] No listener is available for admin virtual host!
2022-04-11 15:58:07.173717 [ERROR] [735980] Fatal error in configuration, exit!
sh
shoaibkk #2
create a new website from cyberpanel and then try
MK
Mirza Khadnezar S [sick] #3
sorry oot
i dont understand
people have cyberpanel
why they still add remove config /web or anything using other panel (outside cyberpanel)
