Closed Cyberpanel not working beacuse, lscpd not starting
MM
Md. Monna Hosain #1
root@server1:~# systemctl status lscpd
× lscpd.service - LSCPD Daemon
Loaded: loaded (/etc/systemd/system/lscpd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2022-04-04 13:29:14 UTC; 17min ago
Main PID: 281 (code=exited, status=255/EXCEPTION)
CGroup: /system.slice/lscpd.service
Apr 04 10:52:07 server1.inbangla.net lscpdctrl[52017]: [OK] lscpd: stopped.
Apr 04 10:52:12 server1.inbangla.net systemd[1]: lscpd.service: Main process exited, code=exited, s>
Apr 04 10:52:12 server1.inbangla.net systemd[1]: lscpd.service: Failed with result ‘exit-code’.
Apr 04 10:52:12 server1.inbangla.net systemd[1]: Stopped LSCPD Daemon.
Apr 04 11:05:18 server1.inbangla.net systemd[1]: Starting LSCPD Daemon…
Apr 04 11:05:19 server1.inbangla.net lscpdctrl[296]: [OK] lscpd: pid=328.
Apr 04 11:05:21 server1.inbangla.net systemd[1]: Started LSCPD Daemon.
Apr 04 11:23:12 server1.inbangla.net systemd[1]: lscpd.service: Main process exited, code=exited, s>
Apr 04 11:23:12 server1.inbangla.net systemd[1]: lscpd.service: Failed with result ‘exit-code’.
Apr 04 11:23:12 server1.inbangla.net systemd[1]: lscpd.service: Unit process 329 (lscpd) remains ru>
lines 1-16/16 (END)
MM
Md. Monna Hosain #2
This is happened after Ubuntu Upgrade using this command: do-release-upgrade
sh
shoaibkk #4
Can you please also share cyberpanel log details here
MM
Md. Monna Hosain #5
root@server1:~# systemctl status cyberpanel
Unit cyberpanel.service could not be found.
root@server1:~#
root@server1:~# /home/cyberpanel/error-logs.txt
-bash: /home/cyberpanel/error-logs.txt: Permission denied
root@server1:~# sh <(curl https://cyberpanel.net/install.sh || wget -O - https://cyberpanel.net/install.sh)
100 1802 100 1802 0 0 4239 0 --:–:-- --:–:-- --:–:-- 4240
-e
Unable to detect your OS…
-e
CyberPanel is supported on Ubuntu 18.04, Ubuntu 20.04, Ubuntu 20.10, CentOS 7.x, CentOS 8.x, CloudLinux 7.x, CloudLinux 8.x and AlmaLinux 8.x…
root@server1:~#
MM
Md. Monna Hosain #6
I updated Ubuntu to 22.04, and Cyberpanel not support Ubuntu 22.04, I think that is the reason Cyberpanel Web Interface not working, but Websites is running ok
