Openlite speed stop responding after upgrading cyberpanel to 2.1.2 and module versions: lsquic 3.0.4,modgzip 1.1,cache 1.64,mod_security 1.4
PR
Pavan Rathod #1
My current litespeed version is 1.7.15 after upgrading.I upgraded my cyberpanel before few days.Since i upgraded my cyberpanel I am getting 502 error suddenly on my all sites.This happens once in a 3-4 days once is restart the server.Here are my server error logs.
2022-04-03 23:45:01.823279 [NOTICE] Using [BoringSSL]
2022-04-03 23:45:01.823608 [NOTICE] [ADMIN] server socket: uds://usr/local/lsws/admin/tmp/admin.sock.7166, fd 6.
2022-04-03 23:45:01.823677 [NOTICE] [57045] [:80] Recovering server socket, fd: 8
2022-04-03 23:45:01.823684 [NOTICE] [57045] Recv listener :80, copy fd 1000 to 8.
2022-04-03 23:45:01.823690 [NOTICE] [57045] [
:80] SO_REUSEPORT #2, recovering server socket, fd: 9.
2022-04-03 23:45:01.823693 [NOTICE] [57045] [
:80] SO_REUSEPORT #3, recovering server socket, fd: 10.
2022-04-03 23:45:01.823696 [NOTICE] [57045] [:80] SO_REUSEPORT #4, recovering server socket, fd: 11.
2022-04-03 23:45:01.823699 [NOTICE] [57045] [
:80] SO_REUSEPORT #5, recovering server socket, fd: 12.
2022-04-03 23:45:01.823702 [NOTICE] [57045] [:443] Recovering server socket, fd: 13
2022-04-03 23:45:01.823706 [NOTICE] [57045] Recv listener :443, copy fd 1005 to 13.
2022-04-03 23:45:01.823709 [NOTICE] [57045] [
:443] SO_REUSEPORT #2, recovering server socket, fd: 14.
2022-04-03 23:45:01.823712 [NOTICE] [57045] [
:443] SO_REUSEPORT #3, recovering server socket, fd: 15.
2022-04-03 23:45:01.823714 [NOTICE] [57045] [:443] SO_REUSEPORT #4, recovering server socket, fd: 16.
2022-04-03 23:45:01.823717 [NOTICE] [57045] [
:443] SO_REUSEPORT #5, recovering server socket, fd: 17.
2022-04-03 23:45:01.823726 [NOTICE] [57045] [UDP *:443] Recovering server socket, SO_REUSEPORT #2, fd: 19
2022-04-03 23:45:01.823729 [NOTICE] [57045] [UDP :443] Recovering server socket, SO_REUSEPORT #3, fd: 21
2022-04-03 23:45:01.823731 [NOTICE] [57045] [UDP :443] Recovering server socket, SO_REUSEPORT #4, fd: 23
2022-04-03 23:45:01.823734 [NOTICE] [57045] [UDP :443] Recovering server socket, SO_REUSEPORT #5, fd: 25
2022-04-03 23:45:01.823738 [NOTICE] [57045] [
:7080] Recovering server socket, fd: 27
2022-04-03 23:45:01.823741 [NOTICE] [57045] Recv listener :7080, copy fd 1015 to 27.
2022-04-03 23:45:01.823750 [NOTICE] [57045] chroot is disabled.
2022-04-03 23:45:01.823754 [INFO] [57045] old priority: 5, new priority: 5
2022-04-03 23:45:01.823830 [INFO] [57045] [config:server:basics2] For better obscurity, server version number is hidden in the response header.
2022-04-03 23:45:01.824426 [INFO] [57045] setuid is allowed in Ext Apps
2022-04-03 23:45:01.824549 [NOTICE] [57045] [PID: 57045]: forked cgid: 57046
2022-04-03 23:45:01.824632 [INFO] [57045] Add QUIC.cloud IPs from admin/conf/quic-cloud-ips to trusted ACL …
2022-04-03 23:45:01.824681 [INFO] [57045] Add CloudFlare Subnets to trusted ACL …
2022-04-03 23:45:01.824714 [INFO] [57045] [PlainConf] [adminConfig:] start parsing file /usr/local/lsws/admin/conf/admin_config.conf
2022-04-03 23:45:01.824807 [INFO] [57045] [PlainConf] [adminConfig:] Finished parsing file /usr/local/lsws/admin/conf/admin_config.conf
2022-04-03 23:45:01.825052 [INFO] [57045] QuicEngine::init(), pid: 57045, log level [warn].
2022-04-03 23:45:01.826630 [INFO] [57045] [Module:mod_security] ParseConfig entry, level 1, Mod_Security v3.0.5
2022-04-03 23:45:01.826857 [INFO] [57045] [Module:mod_security] Enable flag interpreted as 1
2022-04-03 23:45:01.826862 [INFO] [57045] [Module:mod_security] setSecRule value:
secdebugloglevel 0
secdebuglog /usr/local/lsws/logs/modsec.log
secauditengine on
secauditlogrelevantstatus “^(?:5|4(?!04))”
secauditlogparts AFH
secauditlogtype Serial
secauditlog /usr/local/lsws/logs/auditmodsec.log
secruleengine On
, type: 1
2022-04-03 23:45:01.826982 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/custom.conf, type: 2
2022-04-03 23:45:01.827058 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/rules.conf, type: 2
2022-04-03 23:45:01.827196 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/modsecurity.conf, type: 2
2022-04-03 23:45:01.827355 [ERROR] [57045] [Module:mod_security]setSecRule(type 2) /usr/local/lsws/conf/modsec/comodo/modsecurity.conf failed, ret -1, reason: 'Rules error. File: /usr/local/lsws/conf/modsec/comodo/modsecurity.conf. Line: 42. Column: 36. As of ModSecurity version 3.0, SecRequestBodyInMemoryLimit is no longer supported. Instead, you can use your web server configurations to control those values. ModSecurity will follow the web server decision. '.
2022-04-03 23:45:01.827365 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/00_Init_Initialization.conf, type: 2
2022-04-03 23:45:01.827810 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/01_Init_AppsInitialization.conf, type: 2
2022-04-03 23:45:01.828027 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/02_Global_Generic.conf, type: 2
2022-04-03 23:45:01.837083 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/03_Global_Agents.conf, type: 2
2022-04-03 23:45:01.838868 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/04_Global_Domains.conf, type: 2
2022-04-03 23:45:01.839015 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/05_Global_Backdoor.conf, type: 2
2022-04-03 23:45:01.839301 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/06_XSS_XSS.conf, type: 2
2022-04-03 23:45:01.862635 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/07_Global_Other.conf, type: 2
2022-04-03 23:45:01.863950 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/08_Bruteforce_Bruteforce.conf, type: 2
2022-04-03 23:45:01.863998 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/09_HTTP_HTTP.conf, type: 2
2022-04-03 23:45:01.864985 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/10_HTTP_HTTPDoS.conf, type: 2
2022-04-03 23:45:01.865027 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/11_HTTP_Protocol.conf, type: 2
2022-04-03 23:45:01.866785 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/12_HTTP_Request.conf, type: 2
2022-04-03 23:45:01.867065 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/13_Outgoing_FilterGen.conf, type: 2
2022-04-03 23:45:01.868226 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/14_Outgoing_FilterASP.conf, type: 2
2022-04-03 23:45:01.868391 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/15_Outgoing_FilterPHP.conf, type: 2
2022-04-03 23:45:01.870486 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/16_Outgoing_FilterSQL.conf, type: 2
2022-04-03 23:45:01.872555 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/17_Outgoing_FilterOther.conf, type: 2
2022-04-03 23:45:01.873084 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/18_Outgoing_FilterInFrame.conf, type: 2
2022-04-03 23:45:01.873321 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/19_Outgoing_FiltersEnd.conf, type: 2
2022-04-03 23:45:01.873656 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/20_PHP_PHPGen.conf, type: 2
2022-04-03 23:45:01.874543 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/21_SQL_SQLi.conf, type: 2
2022-04-03 23:45:01.878594 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/22_Apps_Joomla.conf, type: 2
2022-04-03 23:45:01.879103 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/23_Apps_JComponent.conf, type: 2
2022-04-03 23:45:01.881041 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/24_Apps_WordPress.conf, type: 2
2022-04-03 23:45:01.881988 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/25_Apps_WPPlugin.conf, type: 2
2022-04-03 23:45:01.911458 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/26_Apps_WHMCS.conf, type: 2
2022-04-03 23:45:01.911619 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/27_Apps_Drupal.conf, type: 2
2022-04-03 23:45:01.917091 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/comodo/28_Apps_OtherApps.conf, type: 2
2022-04-03 23:45:01.965240 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/modsecurity.conf, type: 2
2022-04-03 23:45:01.965417 [ERROR] [57045] [Module:mod_security]setSecRule(type 2) /usr/local/lsws/conf/modsec/owasp/modsecurity.conf failed, ret -1, reason: 'Rules error. File: /usr/local/lsws/conf/modsec/comodo/modsecurity.conf. Line: 42. Column: 36. As of ModSecurity version 3.0, SecRequestBodyInMemoryLimit is no longer supported. Instead, you can use your web server configurations to control those values. ModSecurity will follow the web server decision. Rules error. File: /usr/local/lsws/conf/modsec/owasp/modsecurity.conf. Line: 42. Column: 36. As of ModSecurity version 3.0, SecRequestBodyInMemoryLimit is no longer supported. Instead, you can use your web server configurations to control those values. ModSecurity will follow the web server decision. '.
2022-04-03 23:45:01.965421 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/crs-setup.conf, type: 2
2022-04-03 23:45:01.965910 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-900-EXCLUSION-RULES-BEFORE-CRS.conf, type: 2
2022-04-03 23:45:01.966094 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-901-INITIALIZATION.conf, type: 2
2022-04-03 23:45:01.966761 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-905-COMMON-EXCEPTIONS.conf, type: 2
2022-04-03 23:45:01.967034 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-910-IP-REPUTATION.conf, type: 2
2022-04-03 23:45:01.967956 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-911-METHOD-ENFORCEMENT.conf, type: 2
2022-04-03 23:45:01.968259 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-912-DOS-PROTECTION.conf, type: 2
2022-04-03 23:45:01.968922 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-913-SCANNER-DETECTION.conf, type: 2
2022-04-03 23:45:01.970056 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-921-PROTOCOL-ATTACK.conf, type: 2
2022-04-03 23:45:01.971270 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-930-APPLICATION-ATTACK-LFI.conf, type: 2
2022-04-03 23:45:01.975607 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-931-APPLICATION-ATTACK-RFI.conf, type: 2
2022-04-03 23:45:01.976302 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-932-APPLICATION-ATTACK-RCE.conf, type: 2
2022-04-03 23:45:01.983226 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-933-APPLICATION-ATTACK-PHP.conf, type: 2
2022-04-03 23:45:01.990125 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-941-APPLICATION-ATTACK-XSS.conf, type: 2
2022-04-03 23:45:01.995609 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-942-APPLICATION-ATTACK-SQLI.conf, type: 2
2022-04-03 23:45:02.004627 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-943-APPLICATION-ATTACK-SESSION-FIXATION.conf, type: 2
2022-04-03 23:45:02.005270 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/REQUEST-949-BLOCKING-EVALUATION.conf, type: 2
2022-04-03 23:45:02.005602 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/RESPONSE-950-DATA-LEAKAGES.conf, type: 2
2022-04-03 23:45:02.006049 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/RESPONSE-951-DATA-LEAKAGES-SQL.conf, type: 2
2022-04-03 23:45:02.008598 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/RESPONSE-952-DATA-LEAKAGES-JAVA.conf, type: 2
2022-04-03 23:45:02.009107 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/RESPONSE-953-DATA-LEAKAGES-PHP.conf, type: 2
2022-04-03 23:45:02.011401 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/RESPONSE-954-DATA-LEAKAGES-IIS.conf, type: 2
2022-04-03 23:45:02.012159 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/RESPONSE-959-BLOCKING-EVALUATION.conf, type: 2
2022-04-03 23:45:02.012441 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/RESPONSE-980-CORRELATION.conf, type: 2
2022-04-03 23:45:02.012947 [INFO] [57045] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/owasp/rules/RESPONSE-999-EXCLUSION-RULES-AFTER-CRS.conf, type: 2
2022-04-03 23:45:02.013225 [INFO] [57045] [Module: modcompress 1.1] has been initialized successfully
2022-04-03 23:45:02.013256 [INFO] [57045] [Module: moddecompress 1.1] has been initialized successfully
2022-04-03 23:45:02.013285 [INFO] [57045] [Module: cache 1.64] has been initialized successfully
2022-04-03 23:45:02.013311 [INFO] [57045] [Module: mod_security mod_security 1.4] has been initialized successfully
2022-04-03 23:45:02.013811 [NOTICE] [57045] Reuse current listener [adminListener].
2022-04-03 23:45:02.013847 [NOTICE] [57045] Reuse current listener [Default].
2022-04-03 23:45:02.013850 [INFO] [57045] [
:80] Enable SO_REUSEPORT .
2022-04-03 23:45:02.014293 [NOTICE] [57045] Reuse current listener [SSL].
2022-04-03 23:45:02.014296 [INFO] [57045] [
:443] Enable SO_REUSEPORT .
2022-04-03 23:45:02.014299 [INFO] [57045] [
2022-04-03 23:45:02.014306 [NOTICE] [57045] The maximum number of file descriptor limit is set to 50000.
2022-04-03 23:45:02.014743 [INFO] [57045] [PlainConf] [virtualHostConfig:] start parsing file /usr/local/lsws/conf/vhosts/Example/vhconf.conf
2022-04-03 23:45:02.015044 [INFO] [57045] [PlainConf] [virtualHostConfig:] Finished parsing file /usr/local/lsws/conf/vhosts/Example/vhconf.conf
2022-04-03 23:45:02.015051 [INFO] [57045] [PlainConf] [context:/] rewrite add rules [rewritefile .htaccess]
2022-04-03 23:45:02.015138 [WARN] [57045] [config:server:vhosts:vhost:Example] Uid of /usr/local/lsws/Example/html/ is 0, smaller than minimum requirement 11, use server uid!
2022-04-03 23:45:02.015141 [WARN] [57045] [config:server:vhosts:vhost:Example] Gid of /usr/local/lsws/Example/html/ is 65534, smaller than minimum requirement 10, use server gid!
2022-04-03 23:45:02.015258 [INFO] [57045] [config:server:vhosts:vhost:Example] config context /.
2022-04-03 23:45:02.015273 [INFO] [57045] RewriteFile [.htaccess] parsed, return 0.
2022-04-03 23:45:02.015275 [INFO] [57045] [config:server:vhosts:vhost:Example] config context /blocked/.
2022-04-03 23:45:02.015279 [INFO] [57045] [config:server:vhosts:vhost:Example] config context /cgi-bin/.
2022-04-03 23:45:02.015287 [INFO] [57045] [config:server:vhosts:vhost:Example] config context /docs/.
2022-04-03 23:45:02.015293 [INFO] [57045] [config:server:vhosts:vhost:Example] config context /protected/.
2022-04-03 23:45:02.015353 [INFO] [57045] [PlainConf] [virtualHostConfig:] start parsing file /usr/local/lsws/conf/vhosts/ls1.eccentricbi.com/vhost.conf
2022-04-03 23:45:02.015616 [INFO] [57045] [PlainConf] [virtualHostConfig:] Finished parsing file /usr/local/lsws/conf/vhosts/ls1.eccentricbi.com/vhost.conf
2022-04-03 23:45:02.016281 [INFO] [57045] [config:server:vhosts:vhost:ls1.eccentricbi.com] config context /.
2022-04-03 23:45:02.016293 [INFO] [57045] [config:server:vhosts:vhost:ls1.eccentricbi.com] config context /.well-known.
2022-04-03 23:45:02.016351 [INFO] [57045] [PlainConf] [virtualHostConfig:] start parsing file /usr/local/lsws/conf/vhosts/alderwoodclinic.ca/vhost.conf
2022-04-03 23:45:02.016552 [INFO] [57045] [PlainConf] [virtualHostConfig:] Finished parsing file /usr/local/lsws/conf/vhosts/alderwoodclinic.ca/vhost.conf
2022-04-03 23:45:02.016993 [NOTICE] [57045] [SSL_CTX: 0x24599b0] OCSP Stapling can’t be enabled: [OCSP] /etc/letsencrypt/live/alderwoodclinic.ca/fullchain.pem: X509_STORE_CTX_get1_issuer failed!.
2022-04-03 23:45:02.017054 [INFO] [57045] RewriteFile [/home/alderwoodclinic.ca/public_html/.htaccess] parsed, return 0.
2022-04-03 23:45:02.017100 [INFO] [57045] [PlainConf] [virtualHostConfig:] start parsing file /usr/local/lsws/conf/vhosts/contourmedical.ca/vhost.conf
2022-04-03 23:45:02.017292 [INFO] [57045] [PlainConf] [virtualHostConfig:] Finished parsing file /usr/local/lsws/conf/vhosts/contourmedical.ca/vhost.conf
bypassed. 23:45:02.017976 [INFO] [57045] Rewrite directive:
bypassed. 23:45:02.017980 [INFO] [57045] Rewrite directive:
2022-04-03 23:45:02.017982 [INFO] [57045] Invalid rewrite directive: Options -MultiViews -Indexes
bypassed. 23:45:02.017984 [INFO] [57045] Rewrite directive:
2022-04-03 23:45:02.018007 [INFO] [57045] Rewrite directive: bypassed.
2022-04-03 23:45:02.018009 [INFO] [57045] RewriteFile [/home/contourmedical.ca/public_html/.htaccess] parsed, return 0.
2022-04-03 23:45:02.018056 [INFO] [57045] [PlainConf] [virtualHostConfig:] start parsing file /usr/local/lsws/conf/vhosts/savondrugmart.ca/vhost.conf
2022-04-03 23:45:02.018252 [INFO] [57045] [PlainConf] [virtualHostConfig:] Finished parsing file /usr/local/lsws/conf/vhosts/savondrugmart.ca/vhost.conf
2022-04-03 23:45:02.018793 [NOTICE] [57045] [SSL_CTX: 0x4cde520] OCSP Stapling can’t be enabled: [OCSP] /etc/letsencrypt/live/savondrugmart.ca/fullchain.pem: X509_STORE_CTX_get1_issuer failed!.
2022-04-03 23:45:02.018849 [INFO] [57045] Rewrite directive: bypassed.
2022-04-03 23:45:02.018851 [INFO] [57045] Rewrite directive: bypassed.
2022-04-03 23:45:02.018853 [INFO] [57045] Invalid rewrite directive: Options -MultiViews
2022-04-03 23:45:02.018855 [INFO] [57045] Rewrite directive: bypassed.
2022-04-03 23:45:02.018868 [INFO] [57045] Rewrite directive: bypassed.
2022-04-03 23:45:02.018870 [INFO] [57045] RewriteFile [/home/savondrugmart.ca/public_html/.htaccess] parsed, return 0.
2022-04-03 23:45:02.018916 [INFO] [57045] [PlainConf] [virtualHostConfig:] start parsing file /usr/local/lsws/conf/vhosts/stgeorgeminischool.ca/vhost.conf
2022-04-03 23:45:02.019112 [INFO] [57045] [PlainConf] [virtualHostConfig:] Finished parsing file /usr/local/lsws/conf/vhosts/stgeorgeminischool.ca/vhost.conf
2022-04-03 23:45:02.019563 [NOTICE] [57045] [SSL_CTX: 0x4ced340] OCSP Stapling can’t be enabled: [OCSP] /etc/letsencrypt/live/stgeorgeminischool.ca/fullchain.pem: X509_STORE_CTX_get1_issuer failed!.
2022-04-03 23:45:02.019627 [INFO] [57045] Rewrite directive: bypassed.
2022-04-03 23:45:02.019629 [INFO] [57045] Rewrite directive: bypassed.
2022-04-03 23:45:02.019631 [INFO] [57045] Invalid rewrite directive: Options -MultiViews -Indexes
2022-04-03 23:45:02.019633 [INFO] [57045] Rewrite directive: bypassed.
2022-04-03 23:45:02.019644 [INFO] [57045] Rewrite directive: bypassed.
2022-04-03 23:45:02.019646 [INFO] [57045] Invalid rewrite directive: ExpiresActive On
2022-04-03 23:45:02.019648 [INFO] [57045] Invalid rewrite directive: ExpiresByType image/jpg “access 1 year”
2022-04-03 23:45:02.019650 [INFO] [57045] Invalid rewrite directive: ExpiresByType image/jpeg “access 1 year”
2022-04-03 23:45:02.019655 [INFO] [57045] Invalid rewrite directive: ExpiresByType image/gif “access 1 year”
2022-04-03 23:45:02.019657 [INFO] [57045] Invalid rewrite directive: ExpiresByType image/png “access 1 year”
2022-04-03 23:45:02.019658 [INFO] [57045] Invalid rewrite directive: AddType image/svg+xml .svg
2022-04-03 23:45:02.019660 [INFO] [57045] Invalid rewrite directive: AddOutputFilterByType DEFLATE image/svg+xml
2022-04-03 23:45:02.019662 [INFO] [57045] Invalid rewrite directive: ExpiresByType image/svg+xml “access 1 month”
2022-04-03 23:45:02.019664 [INFO] [57045] Invalid rewrite directive: ExpiresByType text/css “access 1 month”
2022-04-03 23:45:02.019665 [INFO] [57045] Invalid rewrite directive: ExpiresByType application/pdf “access 1 month”
2022-04-03 23:45:02.019667 [INFO] [57045] Invalid rewrite directive: ExpiresByType application/javascript “access 1 month”
2022-04-03 23:45:02.019669 [INFO] [57045] Invalid rewrite directive: ExpiresByType application/x-javascript “access 1 month”
2022-04-03 23:45:02.019671 [INFO] [57045] Invalid rewrite directive: ExpiresByType application/x-shockwave-flash “access 1 month”
2022-04-03 23:45:02.019672 [INFO] [57045] Invalid rewrite directive: ExpiresByType image/x-icon “access 1 year”
2022-04-03 23:45:02.019674 [INFO] [57045] Invalid rewrite directive: ExpiresDefault “access 2 days”
sh
shoaibkk #2
Seems modesecurity is causing issue can you disable that and try
