Wordpress Installation problem
Na
Nazir #1
Installed Cyberpanel and openlitespeed (1-click) on two different VPS but cannot install WordPress using the utility.
Every time installation starts and get message “Installation failed. Error message: invalid literal for int() with base 10: ‘’ [404]”
Is it the package or WordPress problem.
NK
Nitesh Kunnath #2
Please refrain from using the one-click cyberpanel install images from hosting providers. Those are not updated frequently and will have issues (as the codes are older)
What you can now do here is, use the cyberpanel upgrade command mentioned here in the docs section and then update your cyberpanel setup.
Try to disable modsec and see if the issue still exist.
Na
Nazir #3
Thank you for the response, problem solved. I was using a capital letter in the domain name.
sh
shoaibkk #4
the domain will be always in small letters.
These are things need to take care while setting up
