Closed Made a mistake on firewall and need help
JM
John Martin #1
on firewall configuration I remove (my mistake) all the Allow incoming TCP ports, and now i don´t have cyperpanel access. Is there any way to reopen those ports on the shell?
AK
Asma Khalid #2
If you have ssh access, run
systemctl stop firewalld
Then you will get CyberPanel access, you then need to fix firewall from ssh.
JM
John Martin #3
just perfect, but what files do i need to change using nano for example in order to fix it?
FA
Farhan Ali #4
Did you remove iptable rules? or firewalld
MK
Mirza Khadnezar S [sick] #5
please mark solved if your problem is solved
btw:
answer
JM
John Martin #6
I´ve already fixed with backup BUT it´s a great topic to understand. As no ports were open, i could not fix it on cyperpabel (port 8090 was not working). How to activate port 8090?
I tried with ufw allow but it didn´t work
JM
John Martin #7
UPDATE:
As CP is using CFS as firewall ufw doesn´t work.
CSF can be configured on terminal ssh by editing its configuration file csf.conf in /etc/csf:
nano /etc/csf/csf.conf
You must edit the line:
TCP_IN = “20,21,22,25,53,80,110,143,443,465,587,993,995” TCP_OUT = “20,21,22,25,53,80,110,113,443” UDP_IN = “20,21,53” UDP_OUT = “20,21,53,113,123”
The changes can be applied with command:
csf -r
AK
Asma Khalid #9
By the way, CyberPanel by default use firewalld unless you install csf from CyberPanel which disables firewalld.
So this solution only works if you have installed csf.
