/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 1 times Wait for 3 seconds and try again
Mi
Mike #1
I get this error during the installation it retries 50 times then it just exits:
Wait for 3 seconds and try again…
./cyberpanel.sh: line 181: /root/.acme.sh/acme.sh: No such file or directory
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 2 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 3 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 4 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 5 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 6 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 7 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 8 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 9 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 10 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 11 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 12 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 13 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 14 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 15 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 16 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 17 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 18 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 19 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 20 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 21 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 22 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 23 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 24 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 25 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 26 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 27 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 28 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 29 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 30 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 31 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 32 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 33 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 34 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 35 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 36 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 37 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 38 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 39 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 40 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 41 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 42 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 43 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 44 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 45 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 46 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 47 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 48 times
/root/.acme.sh/acme.sh --upgrade --auto-upgrade has failed for 49 times
command /root/.acme.sh/acme.sh --upgrade --auto-upgrade failed for 50 times, exit…
I am using Oracle cloud.
Using Canonical-Ubuntu-20.04-Minimal-2022.02.26-0 Fresh installation.
RM
Rana Muhammad Usman Nasir #2
Run this command on your server, what do you see?
vp
vpscanban.com #3
I also have the same situation as you. Then I installed crontab + openssl and everything worked.
yum install cronie -y
yum install openssl -y
di
dipesh #4
I am also getting the same error that he mentioned above and
as you said to run the command
output = -bash: root/.acme.sh/acme.sh: No such file or directory
di
dipesh #5
any update for this,
I am injecting sh file after just the vps creation but it was failed near to upgrade when the sh file ran automatically. by the way I am using the ols version for more detail
//in retry command its gave errors for acme upgrade how can I resolve the problem
Current_Dir=$(pwd)
Retry_Command “git clone acme.sh: An ACME Shell script, a certbot client: acme.sh”
cd acme.sh || exit
./acme.sh --install
cd “$Current_Dir” || exit
rm -rf acme.sh
shellcheck disable=SC2016
sed -i ‘s|$PROJECT/archive/$BRANCH.tar.gz|https://cyberpanel.sh/codeload.github.com/acmesh-official/acme.sh/tar.gz/master|g’ /root/.acme.sh/acme.sh
Retry_Command “/root/.acme.sh/acme.sh --upgrade --auto-upgrade”
di
dipesh #6
I I tried this but it’s not working for my shell script
AN
Asif Nadeem #7
i got the same error, but i have fixed it with these commands :slight_smile:
cd ~
Download and install acme.sh
curl https://get.acme.sh | sh
source ~/.bashrc
