Backup Retention Not running
Ro
Roberto #1
Hi! I created a backup with automatic retention in CyberPanel, but retention is not working so I don’t keep backups unnecessarily. I put it to have the retention for each backup to delete the previous one. Does anyone know what can it be?
See in the image:
sh
shoaibkk #2
Your cyberpanel installed version?
Ro
Roberto #3
CyberPanel version 2.1
AT
Abdelhadi Touil #4
I have the same issue here. My CyberPanel version is 2.1.2 installed a couple of days before. I was facing the same issue in 2.1.1. The retention option never works, any help please?
Sa
Sangram #5
+1 for this issue… Anyway to debug this?
Mi
Miguel #6
+1 having this issue too, just upgraded to last version to see if it’ll delete the backups, but it still haven’t
OM
Ogün Meriçligil #7
Cyberpanel did not release an update about this, and did not fix the situation,
I solved the situation by writing code myself.
The code is very simple, and it works when you define this code as a cronjob to run once a day.
Important
When you copy the following codes, be sure to set the backup location and renetation time.
Cronjob Line;
0 21 * * * sh /root/ogun-backup.sh >/dev/null 2>&1
ogun-backup.sh content;
echo “Emptying old backup folders…”
#Deleting files older than 10 days
cd /backup/allsites/
find . -mtime +10 > temp.txt
for i in cat temp.txt
do
rm -f $i
done
rm -f temp.txt
echo “Unloaded folders are also being removed…”
find . -type d -empty -delete -maxdepth 1
echo “Old backups deleted.”;
