Hello all,
I updated my CyberPanel instance a few days ago using the Install/Upgrade command since the panel was not up to date. Once the upgrade was successful, I happened to notice the ImmunifyAV component in the Security section of CyberPanel admin interface and clicked on it to check it out and possibly install it.
Since it looked like a convincing plugin, I clicked on install now and I am not sure what exactly happened, nor do I have the log saved but it seemed like the installation had failed. I refreshed the page to make sure that was the case and was faced with an access now button which when I clicked displayed not found error
Could someone kindly guide me on how install this plugin manually or possibly reinstall it through the dashboard
Thank you
