Domain key retrieving problem from Litespeed
JC
Jiban Choudhury #1
Hi guys I’m using cyberpanel with LiteSpeed enterprise but when I’m requesting a domain key I’m not receiving anything insted of that showing an error.
How do I solve this issue? I never faced anything like it It’s trying to fix this for the last few hours.
NK
Nitesh Kunnath #2
Are you able to access https://forexguide247.com/wp-json/litespeed/v1/ ?
Please check.
If not, then some plugins are blocking your wordpress REST Api call…mostly security plugins.
Disable all plugins except litespeed cache and then try to visit the link https://forexguide247.com/wp-json/litespeed/v1/
If you are able to open the link with your site content, then the API call is working. After confirming, you can try issuing domain key and it will work.
