Closed Cyberpanel Installtion Issue- Command not found error
ss
sayan saha #1
I have created a cloud VPS on Hetzner, it has 2GB RAM, 2 vCPUs, and 40GB Disk running on Ubuntu 20.04 LTS version.
For the past few days, I am not able to install Cyberpanel in it.
After running the following command as root user
It gets stuck at the following screen
Capture
No matter, which option I click it returns an error and the installation doesn’t even begin. Even if I type “1”, it returns with “-bash: 1 command not found”. I have tried countless times.
I have tried checking the issues with my friend’s Hetzner account, even though I face the same issue and this installer doesn’t run.
However, If I use AWS, I can install cyberpanel flawlessly using the script. So what’s wrong with my Hetzner cloud server? Any lead?
Need some advice.
MK
Mirza Khadnezar S [sick] #2
it just network connection timeout…
that was happen to my vps too…
after i ask to datacenter to review to config of b/w shaping… everything is fine now
u can learn to use iftop (i use it on my ubuntu) to see the traffic flow
btw you run that command from /usr/local/src
or
root folder :smiley:
sh
shoaibkk #3
Please check with the provider for configurations also reinstall os and try.
