Problem CSF Cyberpanel
ho
hosteko #1
I just created a new tmp in almalinux, because the tmp created by cyberpanel is too small.
after tmp is created, I can’t access CSF, message like this:
Invalid tempfile ownership [/tmp/tmpwtvn8z1f] at /usr/local/csf/bin/cyberpanel.pl line 35.
is anyone having the same problem and can help me solve it?
NK
Nitesh Kunnath #2
chown the tmp in SSH to fix this permission issue.
ho
hosteko #3
if so, what are the permissions for the tmp file? because I see it’s already under root
NK
Nitesh Kunnath #4
I will reproduce this issue and let you know a clear solution.
ho
hosteko #5
Thank you very much for the help, I’m waiting for good news from you
ho
hosteko #6
hello, have you found the problem?
NK
Nitesh Kunnath #7
I tried and haven’t experienced any such issue. Please run this command and send the output here
df -h
login as root and try to chown command on the tmp file you created. Example as below
Navigate to the tmp folder by
cd /path_to_tmp_folder/
Then chown the folder to give permissions
chown FOLDER_NAME X
Se
Selena #8
Thank you very much for the help.
