I can't log to cyberpanel port problem
hi
hicmed #1
Hi I issues hostname all worked fine than I try to fix timezone in PHP Ini with cyberpanel but didn’t work on my website I had to use terminal to set it than I restarted the server now I can’t log in
My websites work fine and can access litespeed panel just cyberpanel won’t get in
I use CloudFlare I changed port to 8443 before issu hostname
So 8090 and 8443 won’t work
Even using just IP with port won’t get in
I’m newbie in vps any help
Thank you
NK
Nitesh Kunnath #2
please PM me your server IP and I will have a check.
