Problem with backups
ET
ELHadj Tahraoui #1
my back up always shows 0MB i dont know why even it was created successfully ?
also i see 0MB in gDrive backups too
RM
Rana Muhammad Usman Nasir #2
Which version of CyberPanel are you using and how did you install it ?
Can you share logs from CyberPanel main log file.
ET
ELHadj Tahraoui #3
thank you for the kind reply
v 2.1 build 2
which log file you want me to provide you
ET
ELHadj Tahraoui #4
look at the picture all scheduled backups are 0MB
screenshot
ET
ELHadj Tahraoui #5
im waiting for the help please
NK
Nitesh Kunnath #6
I will have a check in my test server and let you know if I could reproduce this same error. If not, will you be able to share your server login to check the issue?
ET
ELHadj Tahraoui #7
i found the problem its only backup the public_html files but im using laravel which files needs to be on the root folder which is home/domain.com
any soulution to change backup destination ?
An
AnAlien #8
CyberPanel > Websites > List Websites > Your Site Manage > CONFIGURATIONS TAB in > vHost Conf open.
//First Line
docRoot                   $VH_ROOT/public_html
CHANGE
//First Line
docRoot                   $VH_ROOT/yourlaravelfolder/public
This is how you should create your folder structure. If you are using Cyberpanel with Openlitespeed after this process; You should try to take a backup by restarting the services.
