Help me with cronjob laravel cronjob on cyberpanel
ET
ELHadj Tahraoui #1
ive tried to run cronjob in every way but still not working please help me
here is the command im using laravel php artisan schedule:run
Na
Nada #2
what do you want cronjob do so we can help you ?
did you read this simple guide CronJob
ET
ELHadj Tahraoui #3
thank you for the reply herei want to run a laravel command like this
cd /domain.com && php artisan schedule:run >> /dev/null 2>&1
but it wont work
RM
Rana Muhammad Usman Nasir #4
Can you try
/usr/local/lsws/lshphpXX/bin/php /home/domain.com/public_html/artisan schedule:run >> /dev/null 2>&1
By the way I don’t exactly know how laravel works.
But if you run above command from CLI what happens?
Try following from cli
Note: replace XX with your PHP version like 74 or 80 etc.
ET
ELHadj Tahraoui #6
ive tried it nothing happened i dont know where cron root running path or the log file ?
NK
Nitesh Kunnath #8
Which php version you are using?
Send me a private message with your php version for the domain and also the domain name.
