RAINLOOP admin authentication problem
Ce
Cesare #1
I cannot access the RAINLOOP admin panel.
I enter the credentials and I get “Authentication Failed” (I checked the RAINLOOP password from the terminal and it is the correct one).
When I log in to the RAINLOOP mailbox, everything works correctly.
us
usmannasir #2
Where did you check the rainloop admin password?
Ce
Cesare #3
HI,
From PuTTY with comand " vim /usr/local/CyberCP/public/rainloop.php " and the password is correct and is the same as the one I had.
us
usmannasir #4
Can you again execute this file via php just to make sure that password is set to this.
Ce
Cesare #5
I do not know how to do it. Can you help me ?
Thank you
Ce
Cesare #6
I solved.
I forgot that I had changed the default password to a custom one. However, with the command I indicated, the system shows me the random password it generates during installation and not my custom one.
How can I resolve this message: “RainLoop data folder is accessible. Please configure your web server to hide the data folder from external access. Read more here: Documentation / Installation / RainLoop Webmail”?
us
usmannasir #7
This is false positive, data folder is not accessible.
Go
Goran #8
This is the solution for setting password to rainloop admin. (rainloop/?admin)
Just run:
/usr/bin/php /usr/local/CyberCP/public/rainloop.php
from ssh to set the password.
and then use password from:
