Ram Leak Problem: Ram usage is constantly over 80%
He
HeyTurko #1
I have also installed untouched Cyberpanel on centos 7 many times.
I have done a zero Cyberpanel installation on all versions of ubuntu.
But the result did not change.
I only have 1 or 2 websites on my server. While there is no problem when the server is running for the first time, after a certain period of time, the ram usage rises to over 80% by itself. (And my disk usage is increasing day by day, I don’t understand why.)
I have been using Cyberpanel for many years, but now I am feeling nauseous.
Please help me.
My Server Specs:
Ryzen 9 3950x 4 core, 4 GB Ram, 30 GB NVME SSD
System: Ubuntu 20.04.3 LTS
Codename: focal
OLS or Enterprise?
OpenLiteSpeed
official
no
Install LiteSpeed Memcached?
no
Install Memcached?
no
no
Install Redis?
no
Screenshot of the problem:
us
usmannasir #3
can you give the output of htop command.
us
usmannasir #5
Why do you have so many MySQL processes? what are you running there?
He
HeyTurko #6
@usmannasir I did not do anything.
I installed the official Cyberpanel on the newly installed server.
This is the result I am experiencing.
I don’t know why there are so many Mysql processes.
I am also looking for a solution.
There is only 1 website on Cyberpanel.
ve
vedon #7
I know it has been a long time but did you find any solution to this ? I’m experiencing the same thing with mysql and I have only 1 website on my server. Thanks!
BA
Bahadır Acar #8
I’m also having this problem :frowning:
di
dieselbaby #9
You are not alone, I have also been having this issue, ever since I installed Cyberpanel – on a server that has nothing going on in terms of actual usage, just a couple of sites currently parked. I’ve just learned to ignore it, as far as I’m concerned it’s a bug or something, because the performance has been just fine.
ab
abhishek #10
my website is not getting loaded because of this issue. its not bug its actually my memory is engaged
BA
Bahadır Acar #12
I found a solution. I switched to another control panel.
VL
Vishal Lohar #13
I am experiencing the same problem. Too many MySQL processes. I have to manually restart litespeed every few hours to reduce the usage.
But even after that the ram usage slowly rises back to 90% from 30%.
Can anyone help?
RM
Rana Muhammad Usman Nasir #16
Upgrade CyberPanel and go to 8090/dataBases/MysqlManager
Do you see any slow queries?
VL
Vishal Lohar #17
Its a paid tool. Any free option?
Also,
Recently When I disabled Redis on one of the hosted sites. The RAM usage dropped to 30%.
However, It’s still rising as Redis is enabled on another site.
May be that action triggered Redis to restart
RM
Rana Muhammad Usman Nasir #18
On google you can search how to find slow mysql queries.
From there you will get to know which mysql queries are creating problem then we can try to figure it out.
RM
Rana Muhammad Usman Nasir #20
First query is taking almost 41 seconds ?
SELECT DISTINCT p1.post_id FROM wp_postmeta p1 WHERE p1.meta_value LIKE ?s? AND p1.meta_key IN (?s?,?s?,?s?,?s?,?s?,?s?,?s?)
