Remote backup does not restore anything
Ne
NetHeroes #1
Hello folks,
I want to migrate my websites from an old cyberpanel server to a new one. So when i use the “remote backup” on the new server I’m able to fetch the accounts from the old server and start the transfer.
The logs says everything is fine but the data of the websites simply does not transfer and it does not add a new website on the new server.
Log:
Starting remote Backup
Start date: 11.02.2021_21-53-32
[11.02.2021_21-53-32] Currently generating local backups for: xxxx.com
[11.02.2021_21-53-32] Starting local backup for: xxxx.com
[11.02.2021_21-53-34] Waiting for backup to complete…
[11.02.2021_21-54-00] Backup Completed for: xxxx.com
[11.02.2021_21-54-00] Local Backup Completed for: xxxx.com
[11.02.2021_21-54-00] Sending /home/backup/transfer-2617/backup-xxxx.com-11.02.2021_21-53-32.tar.gz to 193.xxx.xxx.xxx.
[11.02.2021_21-54-00] Sent /home/backup/transfer-2617/backup-xxxx.com-11.02.2021_21-53-32.tar.gz to 193.xxx.xxx.xxx.
[11.02.2021_21-54-00] #############################################
[11.02.2021_21-54-00] Backups are successfully generated and received on: 193.xxx.xxx.xxx
Starting Backup Restore
Start date: 11.02.2021_21-54-02
[11.02.2021_21-54-02] Backup Restore complete
completed[success]`
Both servers are at the same version (2.1 Build 2).
Thank you in advance
Regards :slight_smile:
Go
Goran #3
Same here, did you able to resolve it?
NK
Nitesh Kunnath #4
Make sure the backup file is not empty
Go
Goran #5
It is the script function, we don’t do anything manually here.
NK
Nitesh Kunnath #6
Please provide more details so that we can have a look or send us a temporary login to the affected server where we can see this error so that we can try to fix it or let you know what exactly went wrong with your settings.
ra
rafaelsantos #7
Has any solution appeared? I have the same problem here in 2024. SSH port 22. API access granted. Sites are backed up on the source server, but are not transferred to the destination server.
