Fresh 2.12 Installation failed (We are not able to run systemctl start mysql )
Za
Zalcig #1
Provider: Hetzner
Virtualization Type: KVM, vmware
System: Centos 7.7
Installation option: since during the installation.
there will be few option to choose,so please provide it as well.
OLS or Enterprise?
OLS
official
yes
Install LiteSpeed Memcached?
yes
Install Memcached?
yes
yes
Install Redis?
yes
Cyberpanel version
Tried blow versions
2.1.2
2.1.1
2.0.3
Problem:
When I try to install fresh cyberpanel into a fresh VPS , it fails and show error message below
[10.22.2021_17-03-10] Fixing OpenLiteSpeed configurations!,50
[10.22.2021_17-03-10] OpenLiteSpeed Configurations fixed!,50
[10.22.2021_17-03-10] Running: /usr/local/lsws/bin/lswsctrl restart,50
[10.22.2021_17-03-13] Successfully ran: /usr/local/lsws/bin/lswsctrl restart.,50
[10.22.2021_17-03-13] Installing MySQL,60
[10.22.2021_17-03-13] Running: yum --enablerepo=mariadb -y install MariaDB-server MariaDB-client,60
[10.22.2021_17-03-38] Successfully ran: yum --enablerepo=mariadb -y install MariaDB-server MariaDB-client.,60
[10.22.2021_17-03-38] Running: systemctl start mysql,60
[10.22.2021_17-03-38] [ERROR] We are not able to run systemctl start mysql return code: 5. Fatal error, see /var/log/installLogs.txt for full details.
Oops, something went wrong… [404]
I tried to reinstall couple of times from other providers unfortunately result is the same.
When I check systemctl status mysqld or MySQL service not found.
However when I try yum install MySQL it shows its already installed .
installogx as above, I was able to install everyday until 2.1.2 release…
th
thierry #2
I have same issues : We are not able to run systemctl start mysql return code: 5. Fatal error,
lu
luxmant354 #3
th
thierry #4
OS was centos 7.4 updated ; selected latest cyberpanel version; tried again on centos 8.4.2105 installation was succesfull
lu
luxmant354 #5
ok i will try
