rainloop mail problem
hi
hilgard #1
i install cyberpannel and cant login to rainloop by this error( Can’t connect to server).when i test on rainloop andmin pannel/ domains show ssl://mydomain.com:93 connection refused .when i try this command
journalctl -f | grep postfix
dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727490]: F186B1C6561: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=151729, delays=151725/4.3/0/0.4, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727462]: F01581C6243: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=273408, delays=273404/4.3/0/0.34, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727501]: 8669F1C628D: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=260989, delays=260984/4.2/0/0.53, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727515]: F2C8F1C65F8: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=126528, delays=126524/4.3/0/0.39, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727485]: 3B36C1C65C7: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=134988, delays=134983/4.5/0/0.22, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727580]: 35D611C42D6: to=root@mydomain.com, relay=dovecot, delay=374333, delays=374328/3.8/0/0.93, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727539]: 3ED401C61C2: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=294469, delays=294464/4.5/0/0.22, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727624]: 307751C657A: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=147589, delays=147584/4.5/0/0.23, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727620]: 3CA1A1C6579: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=147768, delays=147763/4.5/0/0.24, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727477]: 30E141C689C: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=4741, delays=4736/4.5/0/0.23, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727465]: F21041C641C: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=206339, delays=206335/4.4/0/0.38, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727587]: 3531E1C6805: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=30048, delays=30043/4.5/0/0.24, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727480]: F38A11C668D: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=97369, delays=97365/4.4/0/0.39, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727665]: 84CAD1C613F: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=315373, delays=315368/4/0/0.74, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:20:52 mydomain postfix/pipe[727468]: 8D6A61C6501: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=168649, delays=168644/4.1/0/0.65, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:21:03 mydomain postfix/pickup[727254]: D094A1C68BB: uid=0 from=
Oct 07 13:21:03 mydomain postfix/cleanup[727719]: D094A1C68BB: message-id=20211007095103.D094A1C68BB@mail.mydomain.com
Oct 07 13:21:03 mydomain postfix/qmgr[713297]: D094A1C68BB: from=root@mail.mydomain.com, size=1017, nrcpt=1 (queue active)
Oct 07 13:21:03 mydomain postfix/pipe[727545]: D094A1C68BB: to=root@mail.mydomain.com, orig_to=, relay=dovecot, delay=0.08, delays=0.05/0/0/0.03, dsn=4.3.0, status=deferred (temporary failure)
Oct 07 13:21:27 mydomain postfix/anvil[727410]: statistics: max connection rate 1/60s for (smtp:212.192.241.87) at Oct 7 13:19:46
Oct 07 13:21:27 mydomain postfix/anvil[727410]: statistics: max connection count 1 for (smtp:212.192.241.87) at Oct 7 13:19:46
Oct 07 13:21:27 mydomain postfix/anvil[727410]: statistics: max cache size 1 at Oct 7 13:19:46
hi
hilgard #2
in cyberpannel main log i give this error
[10.07.2021_08-22-47] (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’)). [31:404]
i create two web site and problem exist on all of them
