Error while using REMOTE SQL
mi
miaudigitalagency #1
Hi Everyone :wink: greetings from Lisbon!
Does everyone know why when i tried to install cyberpanel with remote sql i always get
[ERROR] We are not able to run /usr/local/CyberPanel/bin/python manage.py makemigrations return code: 1. Fatal error
Preceded by a
MySQLdb._exceptions.OperationalError: (1045, “Access denied for user ‘cyberpanel’@‘192.168.166.96’ (using password: YES)”)
I can log in from server to remote sql sever using mysql cmd line
Any suggestion
at
atiroop #2
Have you ever tried install without remote sql option? you may install without remote sql option, once it’s done and the panel work ok, then you can modify sql cnf file @ bind-address later (in case you want to remote to your sql server).
