How to check if memcached work?
ph
phuongdzu #1
Hello everybody
I check phpinfo, and shows Memcached showed, but not sure if it works.
Because before use Cyberpanel, I can see memcached show live time in top comment, but with Cyberpanel I never see Memcached.
Please help me how to check for sure memcached works
Thanks
ph
phuongdzu #2
Exactly Memcached is not working.
Anyone can help me to fix
Thanks
The script says:
“You enabled Memcache caching in the Server Settings but script could not connect to Memcache using parameters specified in your script. Check the Memcache server and accuracy of its connection settings in the Script Settings. Otherwise, enable file caching in in the Script Settings.”
sh
shoaibkk #5
Memcache PHP extension is installed? @phuongdzu
