Problem getting SpamAssassin working
st
starbursthost #1
First off, this is on a AlmaLinux 8.4 box.
I really don’t want to bring up another el8 box 5 months before EOL.
Am getting, “Installation failed. Failed to install SpamAssassin configurations.”
But right under:
Last metadata expiration check: 14:02:06 ago on Wed Jul 7 23:02:38 2021.
Dependencies resolved.
Package Arch Version Repository Size
Installing:
spamassassin x86_64 3.4.4-3.el8 appstream 1.3 M
Installing dependencies:
perl-Crypt-OpenSSL-Bignum x86_64 0.09-5.el8 appstream 46 k
perl-Crypt-OpenSSL-RSA x86_64 0.31-1.el8 appstream 46 k
perl-Crypt-OpenSSL-Random x86_64 0.15-3.el8 appstream 30 k
perl-IO-Socket-INET6 noarch 2.72-12.el8 appstream 33 k
perl-IO-String noarch 1.08-32.el8 appstream 20 k
perl-Mail-DKIM noarch 0.54-1.el8 appstream 162 k
perl-Mail-SPF noarch 2.9.0-15.el8 appstream 152 k
perl-MailTools noarch 2.20-2.el8 appstream 112 k
perl-Net-DNS noarch 1.15-1.el8 appstream 369 k
perl-Net-SMTP-SSL noarch 1.04-5.el8 appstream 15 k
perl-NetAddr-IP x86_64 4.079-7.el8 appstream 132 k
perl-Socket6 x86_64 0.28-6.el8 appstream 36 k
procmail x86_64 3.22-47.el8 appstream 180 k
Transaction Summary
Install 14 Packages
Total download size: 2.6 M
Installed size: 6.8 M
Downloading Packages:
(1/14): perl-Crypt-OpenSSL-Random-0.15-3.el8.x8 560 kB/s | 30 kB 00:00
(2/14): perl-Crypt-OpenSSL-RSA-0.31-1.el8.x86_6 749 kB/s | 46 kB 00:00
(3/14): perl-Crypt-OpenSSL-Bignum-0.09-5.el8.x8 547 kB/s | 46 kB 00:00
(4/14): perl-IO-String-1.08-32.el8.noarch.rpm 693 kB/s | 20 kB 00:00
(5/14): perl-IO-Socket-INET6-2.72-12.el8.noarch 876 kB/s | 33 kB 00:00
(6/14): perl-Mail-SPF-2.9.0-15.el8.noarch.rpm 2.7 MB/s | 152 kB 00:00
(7/14): perl-MailTools-2.20-2.el8.noarch.rpm 2.0 MB/s | 112 kB 00:00
(8/14): perl-Mail-DKIM-0.54-1.el8.noarch.rpm 1.8 MB/s | 162 kB 00:00
(9/14): perl-Net-SMTP-SSL-1.04-5.el8.noarch.rpm 531 kB/s | 15 kB 00:00
(10/14): perl-Socket6-0.28-6.el8.x86_64.rpm 927 kB/s | 36 kB 00:00
(11/14): perl-Net-DNS-1.15-1.el8.noarch.rpm 4.8 MB/s | 369 kB 00:00
(12/14): perl-NetAddr-IP-4.079-7.el8.x86_64.rpm 2.3 MB/s | 132 kB 00:00
(13/14): procmail-3.22-47.el8.x86_64.rpm 1.7 MB/s | 180 kB 00:00
(14/14): spamassassin-3.4.4-3.el8.x86_64.rpm 8.6 MB/s | 1.3 MB 00:00
Total 2.8 MB/s | 2.6 MB 00:00
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : perl-Net-DNS-1.15-1.el8.noarch 1/14
Installing : perl-Socket6-0.28-6.el8.x86_64 2/14
Installing : perl-NetAddr-IP-4.079-7.el8.x86_64 3/14
Installing : perl-Mail-SPF-2.9.0-15.el8.noarch 4/14
Running scriptlet: perl-Mail-SPF-2.9.0-15.el8.noarch 4/14
Installing : perl-IO-Socket-INET6-2.72-12.el8.noarch 5/14
Installing : procmail-3.22-47.el8.x86_64 6/14
Installing : perl-Net-SMTP-SSL-1.04-5.el8.noarch 7/14
Installing : perl-MailTools-2.20-2.el8.noarch 8/14
Installing : perl-IO-String-1.08-32.el8.noarch 9/14
Installing : perl-Crypt-OpenSSL-Random-0.15-3.el8.x86_64 10/14
Installing : perl-Crypt-OpenSSL-Bignum-0.09-5.el8.x86_64 11/14
Installing : perl-Crypt-OpenSSL-RSA-0.31-1.el8.x86_64 12/14
Installing : perl-Mail-DKIM-0.54-1.el8.noarch 13/14
Installing : spamassassin-3.4.4-3.el8.x86_64 14/14
Running scriptlet: spamassassin-3.4.4-3.el8.x86_64 14/14
Verifying : perl-Crypt-OpenSSL-Bignum-0.09-5.el8.x86_64 1/14
Verifying : perl-Crypt-OpenSSL-RSA-0.31-1.el8.x86_64 2/14
Verifying : perl-Crypt-OpenSSL-Random-0.15-3.el8.x86_64 3/14
Verifying : perl-IO-Socket-INET6-2.72-12.el8.noarch 4/14
Verifying : perl-IO-String-1.08-32.el8.noarch 5/14
Verifying : perl-Mail-DKIM-0.54-1.el8.noarch 6/14
Verifying : perl-Mail-SPF-2.9.0-15.el8.noarch 7/14
Verifying : perl-MailTools-2.20-2.el8.noarch 8/14
Verifying : perl-Net-DNS-1.15-1.el8.noarch 9/14
Verifying : perl-Net-SMTP-SSL-1.04-5.el8.noarch 10/14
Verifying : perl-NetAddr-IP-4.079-7.el8.x86_64 11/14
Verifying : perl-Socket6-0.28-6.el8.x86_64 12/14
Verifying : procmail-3.22-47.el8.x86_64 13/14
Verifying : spamassassin-3.4.4-3.el8.x86_64 14/14
Installed:
Complete!
SpamAssassin Installed.[200]
st
starbursthost #2
spamassassin.service - Spamassassin daemon
Loaded: loaded (/usr/lib/systemd/system/spamassassin.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2021-07-08 13:11:22 UTC; 2s ago
Main PID: 50533 (spamd)
Tasks: 3 (limit: 49482)
Memory: 91.4M
CGroup: /system.slice/spamassassin.service
├─50533 /usr/bin/perl -T -w /usr/bin/spamd -c -m5 -H --razor-home-dir=/var/lib/razor/ --razor-log-file=sy>
├─50538 spamd child >
└─50539 spamd child
No error messages can be found onscreen on in log files.
