Remote Backups doesn't work on 2.0.3 on fresh installation
Za
Zalcig #1
Provider: SELF
Virtualization Type: vmware ESXI
System: Centos 7.7
Installation option: Full installation
OLS or Enterprise?
OLS
official
yes
Install LiteSpeed Memcached?
yes
Install Memcached?
yes
yes
Install Redis?
yes
Problem:
On clean fresh setup for both servers 2.0.3
When I try to use REMOTE BACKUP , it connects to remote server, allows me to select which website to restore, after selecting and starting it stuck with below message
cat: /home/backup/transfer-1675/backup_log: No such file or directory
I tried re-install on clean centos 7 but still happens.
I found older version of cyberpanel 1.9.7 it works perfectly with the same setup
ti
timnolte #2
Have you had any success, I’m still seeing that this is an issue. I was hoping to transfer my CyberPanel setup from my AWS hosting to my new DigitalOcean hosting but it looks like I’m going to have to do a manual setup/transfer.
Za
Zalcig #3
unfortunately still not working also tested with the newest version I’m not sure what is wrong as it doesn’t work with fresh installed servers
