SSL Problems
Ba
Bazsi15 #1
Soo i’m trying to get ssl form cyberpanel to this domain its on the good nameserver and dns
Cyberpanel tries to get me ssl and it sais it succesfull but then it i check the cyberpanel log:
[03.25.2021_12-05-04] /root/.acme.sh/acme.sh --issue -d myrget5.tk -d www.myrget5.tk --cert-file /etc/letsencrypt/live/myrget5.tk/cert.pem --key-file /etc/letsencrypt/live/myrget5.tk/privkey.pem --fullchain-file /etc/letsencrypt/live/myrget5.tk/fullchain.pem -w /home/myrget5.tk/public_html --force
[03.25.2021_12-05-14] Failed to obtain SSL for: myrget5.tk and: www.myrget5.tk
[03.25.2021_12-05-14] Trying to obtain SSL for: myrget5.tk
[03.25.2021_12-05-21] Failed to obtain SSL, issuing self-signed SSL for: myrget5.tk
[03.25.2021_12-05-22] Self signed SSL issued for myrget5.tk.
then i tried it manually with no success but maybe more information:
[Thu Mar 25 13:27:16 CET 2021] Running cmd: issue
[Thu Mar 25 13:27:16 CET 2021] _main_domain=‘myrget5.tk’
[Thu Mar 25 13:27:16 CET 2021] _alt_domains=‘www.myrget5.tk’
[Thu Mar 25 13:27:16 CET 2021] Using config home:/root/.acme.sh
[Thu Mar 25 13:27:16 CET 2021] default_acme_server
[Thu Mar 25 13:27:16 CET 2021] ACME_DIRECTORY=‘https://acme-v02.api.letsencrypt.org/directory’
[Thu Mar 25 13:27:16 CET 2021] DOMAIN_PATH=‘/root/.acme.sh/myrget5.tk’
[Thu Mar 25 13:27:16 CET 2021] Using ACME_DIRECTORY: https://acme-v02.api.letsencrypt.org/directory
[Thu Mar 25 13:27:16 CET 2021] _init api for server: https://acme-v02.api.letsencrypt.org/directory
[Thu Mar 25 13:27:16 CET 2021] GET
[Thu Mar 25 13:27:16 CET 2021] url=‘https://acme-v02.api.letsencrypt.org/directory’
[Thu Mar 25 13:27:16 CET 2021] timeout=
[Thu Mar 25 13:27:16 CET 2021] _CURL=‘curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Thu Mar 25 13:27:16 CET 2021] ret=‘0’
[Thu Mar 25 13:27:17 CET 2021] ACME_KEY_CHANGE=‘https://acme-v02.api.letsencrypt.org/acme/key-change’
[Thu Mar 25 13:27:17 CET 2021] ACME_NEW_AUTHZ
[Thu Mar 25 13:27:17 CET 2021] ACME_NEW_ORDER=‘https://acme-v02.api.letsencrypt.org/acme/new-order’
[Thu Mar 25 13:27:17 CET 2021] ACME_NEW_ACCOUNT=‘https://acme-v02.api.letsencrypt.org/acme/new-acct’
[Thu Mar 25 13:27:17 CET 2021] ACME_REVOKE_CERT=‘https://acme-v02.api.letsencrypt.org/acme/revoke-cert’
[Thu Mar 25 13:27:17 CET 2021] ACME_AGREEMENT=‘https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf’
[Thu Mar 25 13:27:17 CET 2021] ACME_NEW_NONCE=‘https://acme-v02.api.letsencrypt.org/acme/new-nonce’
[Thu Mar 25 13:27:17 CET 2021] ACME_VERSION=‘2’
[Thu Mar 25 13:27:17 CET 2021] Le_NextRenewTime
[Thu Mar 25 13:27:17 CET 2021] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Thu Mar 25 13:27:17 CET 2021] _on_before_issue
[Thu Mar 25 13:27:17 CET 2021] _chk_main_domain=‘myrget5.tk’
[Thu Mar 25 13:27:17 CET 2021] _chk_alt_domains=‘www.myrget5.tk’
[Thu Mar 25 13:27:17 CET 2021] Le_LocalAddress
[Thu Mar 25 13:27:17 CET 2021] d=‘myrget5.tk’
[Thu Mar 25 13:27:17 CET 2021] Check for domain=‘myrget5.tk’
[Thu Mar 25 13:27:17 CET 2021] _currentRoot=’/home/myrget5.tk/public_html’
[Thu Mar 25 13:27:17 CET 2021] d=‘www.myrget5.tk’
[Thu Mar 25 13:27:17 CET 2021] Check for domain=‘www.myrget5.tk’
[Thu Mar 25 13:27:17 CET 2021] _currentRoot=‘/home/myrget5.tk/public_html’
[Thu Mar 25 13:27:17 CET 2021] _saved_account_key_hash is not changed, skip register account.
[Thu Mar 25 13:27:17 CET 2021] Read key length:
[Thu Mar 25 13:27:17 CET 2021] _createcsr
[Thu Mar 25 13:27:17 CET 2021] Multi domain=‘DNS:myrget5.tk,DNS:www.myrget5.tk’
[Thu Mar 25 13:27:17 CET 2021] Getting domain auth token for each domain
[Thu Mar 25 13:27:17 CET 2021] url=‘https://acme-v02.api.letsencrypt.org/acme/new-order’
[Thu Mar 25 13:27:17 CET 2021] payload=‘{“identifiers”: [{“type”:“dns”,“value”:“myrget5.tk”},{“type”:“dns”,“value”:“www.myrget5.tk”}]}’
[Thu Mar 25 13:27:17 CET 2021] RSA key
[Thu Mar 25 13:27:17 CET 2021] HEAD
[Thu Mar 25 13:27:17 CET 2021] _post_url=‘https://acme-v02.api.letsencrypt.org/acme/new-nonce’
[Thu Mar 25 13:27:17 CET 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g -I ’
[Thu Mar 25 13:27:18 CET 2021] _ret=‘0’
[Thu Mar 25 13:27:18 CET 2021] POST
[Thu Mar 25 13:27:18 CET 2021] _post_url=‘https://acme-v02.api.letsencrypt.org/acme/new-order’
[Thu Mar 25 13:27:18 CET 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Thu Mar 25 13:27:19 CET 2021] code=‘429’
[Thu Mar 25 13:27:19 CET 2021] Le_LinkOrder
[Thu Mar 25 13:27:19 CET 2021] Le_OrderFinalize
[Thu Mar 25 13:27:19 CET 2021] Create new order error. Le_OrderFinalize not found. {
“type”: “urn:ietf:params:acme:error:rateLimited”,
“detail”: “Error creating new order :: too many failed authorizations recently: see Rate Limits - Let's Encrypt”,
“status”: 429
[Thu Mar 25 13:27:19 CET 2021] pid
[Thu Mar 25 13:27:19 CET 2021] No need to restore nginx, skip.
[Thu Mar 25 13:27:19 CET 2021] _clearupdns
[Thu Mar 25 13:27:19 CET 2021] dns_entries
[Thu Mar 25 13:27:19 CET 2021] skip dns.
[Thu Mar 25 13:27:19 CET 2021] _on_issue_err
[Thu Mar 25 13:27:19 CET 2021] Please check log file for more details: /root/.acme.sh/acme.sh.log
Maybe that can help that i dont have ssl on my panel either but i think that doesn’t matters…
Can somebody help me with this? :sweat_smile:
Ba
Bazsi15 #2
Oh and the self signed isn’t working either the cert says www.example.com on the site
