WEB HOSTING CONTROL PANEL FOR EVERYONE
sr
srirtx #1
Thanks for reaching out to us.
I understand you are unable to access the CyberPanel due to the wrong password message.
As a self-managed provider, we are not able to directly access the droplet to review, install or manage software or the environment. This will need to be done directly by you, though we are glad to provide guidance on things you encounter.
By default, your username is admin and you can get your password from:
sudo cat .litespeed_password
Run the following command to reset the admin password:
adminPass newpassword
You can also refer to below forums:
i followed same but still i cannot do wasting of my times
Pi
Pimmal #2
And what exactly is your problem or question? I dont find any question were somebody can help you out or answer.
