Custom Theme Build for Cyberpanel
ss
shahin_sha #1
Hey, I customize cyberpanel dashboard theme. I used Ubold - Admin & Dashboard Template Link Ubold - Admin & Dashboard Template by coderthemes | ThemeForest
My customize complete after 5 days.
The problem will be if I update the cyberpanel. I need to know how I update cyberpanel from my self-host.
Because I changed all dashboard design and change asset directory. Before was: public/static/file folder/file name
Now for admin: public/static/admin/file folder/file name
Now for client: public/static/client/file folder/file name
I changed the dir for security purposes
Thank you @usman for great cpanel.
us
usmannasir #2
If you can share your designs with our community, please contact our support for help. :slight_smile:
