Unable to issue SSL through interface or CLI
km
kmpmba #1
New install - VPS - version 2.1 build 1 - Ubuntu 20.04
Log File:
[06.19.2021_09-35-18] /root/.acme.sh/acme.sh --issue -d mydomain.com -d www.mydomain.com --cert-file /etc/letsencrypt/live/mydomain.com/cert.pem --key-file /etc/letsencrypt/live/mydomain.com/privkey.pem --fullchain-file /etc/letsencrypt/live/mydomain.com/fullchain.pem -w /home/mydomain.com/public_html --force
[06.19.2021_09-36-39] Failed to obtain SSL for: mydomain.com and: www.mydomain.com
[06.19.2021_09-36-39] Trying to obtain SSL for: mydomain.com
[06.19.2021_09-37-58] Failed to obtain SSL, issuing self-signed SSL for: mydomain.com
[06.19.2021_09-37-58] Self signed SSL issued for mydomain.com.
[06.19.2021_10-13-34] Trying to obtain SSL for: mydomain.com and: www.mydomain.com
[06.19.2021_10-13-34] /root/.acme.sh/acme.sh --issue -d mydomain.com -d www.mydomain.com --cert-file /etc/letsencrypt/live/mydomain.com/cert.pem --key-file /etc/letsencrypt/live/mydomain.com/privkey.pem --fullchain-file /etc/letsencrypt/live/mydomain.com/fullchain.pem -w /home/mydomain.com/public_html --force
[06.19.2021_10-14-54] Failed to obtain SSL for: mydomain.com and: www.mydomain.com
[06.19.2021_10-14-54] Trying to obtain SSL for: mydomain.com
[06.19.2021_10-16-13] Failed to obtain SSL, issuing self-signed SSL for: mydomain.com
[06.19.2021_10-16-13] Self signed SSL issued for mydomain.com.
CLI Log:
[Sat 19 Jun 2021 10:21:35 AM UTC] Running cmd: issue
[Sat 19 Jun 2021 10:21:35 AM UTC] _main_domain=‘mydomain.com’
[Sat 19 Jun 2021 10:21:35 AM UTC] _alt_domains=‘www.mydomain.com’
[Sat 19 Jun 2021 10:21:35 AM UTC] Using config home:/root/.acme.sh
[Sat 19 Jun 2021 10:21:35 AM UTC] default_acme_server
[Sat 19 Jun 2021 10:21:35 AM UTC] ACME_DIRECTORY=‘https://acme.zerossl.com/v2/DV90’
[Sat 19 Jun 2021 10:21:35 AM UTC] DOMAIN_PATH=‘/root/.acme.sh/mydomain.com’
[Sat 19 Jun 2021 10:21:35 AM UTC] Using ACME_DIRECTORY: https://acme.zerossl.com/v2/DV90
[Sat 19 Jun 2021 10:21:35 AM UTC] _init api for server: https://acme.zerossl.com/v2/DV90
[Sat 19 Jun 2021 10:21:35 AM UTC] GET
[Sat 19 Jun 2021 10:21:35 AM UTC] url=‘https://acme.zerossl.com/v2/DV90’
[Sat 19 Jun 2021 10:21:35 AM UTC] timeout=
[Sat 19 Jun 2021 10:21:35 AM UTC] _CURL=‘curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Sat 19 Jun 2021 10:21:35 AM UTC] ret=‘0’
[Sat 19 Jun 2021 10:21:35 AM UTC] ACME_KEY_CHANGE=‘https://acme.zerossl.com/v2/DV90/keyChange’
[Sat 19 Jun 2021 10:21:35 AM UTC] ACME_NEW_AUTHZ
[Sat 19 Jun 2021 10:21:35 AM UTC] ACME_NEW_ORDER=‘https://acme.zerossl.com/v2/DV90/newOrder’
[Sat 19 Jun 2021 10:21:35 AM UTC] ACME_NEW_ACCOUNT=‘https://acme.zerossl.com/v2/DV90/newAccount’
[Sat 19 Jun 2021 10:21:35 AM UTC] ACME_REVOKE_CERT=‘https://acme.zerossl.com/v2/DV90/revokeCert’
[Sat 19 Jun 2021 10:21:35 AM UTC] ACME_AGREEMENT=‘https://secure.trust-provider.com/repository/docs/Legacy/20201020_Certificate_Subscriber_Agreement_v_2_4_click.pdf’
[Sat 19 Jun 2021 10:21:35 AM UTC] ACME_NEW_NONCE=‘https://acme.zerossl.com/v2/DV90/newNonce’
[Sat 19 Jun 2021 10:21:35 AM UTC] Le_NextRenewTime
[Sat 19 Jun 2021 10:21:35 AM UTC] Using CA: https://acme.zerossl.com/v2/DV90
[Sat 19 Jun 2021 10:21:35 AM UTC] _on_before_issue
[Sat 19 Jun 2021 10:21:35 AM UTC] _chk_main_domain=‘mydomain.com’
[Sat 19 Jun 2021 10:21:35 AM UTC] _chk_alt_domains=‘www.mydomain.com’
[Sat 19 Jun 2021 10:21:35 AM UTC] Le_LocalAddress
[Sat 19 Jun 2021 10:21:35 AM UTC] d=‘mydomain.com’
[Sat 19 Jun 2021 10:21:35 AM UTC] Check for domain=‘mydomain.com’
[Sat 19 Jun 2021 10:21:35 AM UTC] _currentRoot=’/home/mydomain.com/public_html’
[Sat 19 Jun 2021 10:21:35 AM UTC] d=‘www.mydomain.com’
[Sat 19 Jun 2021 10:21:35 AM UTC] Check for domain=‘www.mydomain.com’
[Sat 19 Jun 2021 10:21:35 AM UTC] _currentRoot=‘/home/mydomain.com/public_html’
[Sat 19 Jun 2021 10:21:35 AM UTC] _saved_account_key_hash is not changed, skip register account.
[Sat 19 Jun 2021 10:21:35 AM UTC] Read key length:
[Sat 19 Jun 2021 10:21:35 AM UTC] _createcsr
[Sat 19 Jun 2021 10:21:35 AM UTC] Multi domain=‘DNS:mydomain.com,DNS:www.mydomain.com’
[Sat 19 Jun 2021 10:21:35 AM UTC] Getting domain auth token for each domain
[Sat 19 Jun 2021 10:21:35 AM UTC] url=‘https://acme.zerossl.com/v2/DV90/newOrder’
[Sat 19 Jun 2021 10:21:35 AM UTC] payload=‘{“identifiers”: [{“type”:“dns”,“value”:“mydomain.com”},{“type”:“dns”,“value”:“www.mydomain.com”}]}’
[Sat 19 Jun 2021 10:21:35 AM UTC] RSA key
[Sat 19 Jun 2021 10:21:35 AM UTC] HEAD
[Sat 19 Jun 2021 10:21:35 AM UTC] _post_url=‘https://acme.zerossl.com/v2/DV90/newNonce’
[Sat 19 Jun 2021 10:21:35 AM UTC] _CURL=‘curl --silent --dump-header /root/.acme.sh/http.header -L -g -I ’
[Sat 19 Jun 2021 10:21:36 AM UTC] _ret=‘0’
[Sat 19 Jun 2021 10:21:36 AM UTC] POST
[Sat 19 Jun 2021 10:21:36 AM UTC] _post_url=‘https://acme.zerossl.com/v2/DV90/newOrder’
[Sat 19 Jun 2021 10:21:36 AM UTC] _CURL=‘curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Sat 19 Jun 2021 10:21:37 AM UTC] _ret=‘0’
[Sat 19 Jun 2021 10:21:37 AM UTC] code=‘201’
[Sat 19 Jun 2021 10:21:37 AM UTC] Le_LinkOrder=‘https://acme.zerossl.com/v2/DV90/order/Ek8Ig5F6iqmmK1NR32G7sw’
[Sat 19 Jun 2021 10:21:37 AM UTC] Le_OrderFinalize=‘https://acme.zerossl.com/v2/DV90/order/Ek8Ig5F6iqmmK1NR32G7sw/finalize’
[Sat 19 Jun 2021 10:21:37 AM UTC] url=‘https://acme.zerossl.com/v2/DV90/authz/jDuNKISOctG3qAdbsQ_MXQ’
[Sat 19 Jun 2021 10:21:37 AM UTC] payload
[Sat 19 Jun 2021 10:21:37 AM UTC] POST
[Sat 19 Jun 2021 10:21:37 AM UTC] _post_url=‘https://acme.zerossl.com/v2/DV90/authz/jDuNKISOctG3qAdbsQ_MXQ’
[Sat 19 Jun 2021 10:21:37 AM UTC] _CURL=‘curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Sat 19 Jun 2021 10:21:38 AM UTC] _ret=‘0’
[Sat 19 Jun 2021 10:21:38 AM UTC] code=‘200’
[Sat 19 Jun 2021 10:21:38 AM UTC] url=‘https://acme.zerossl.com/v2/DV90/authz/M-cT_GI5_ktt5N_1m0QAdA’
[Sat 19 Jun 2021 10:21:38 AM UTC] payload
[Sat 19 Jun 2021 10:21:38 AM UTC] POST
[Sat 19 Jun 2021 10:21:38 AM UTC] _post_url=‘https://acme.zerossl.com/v2/DV90/authz/M-cT_GI5_ktt5N_1m0QAdA’
[Sat 19 Jun 2021 10:21:38 AM UTC] _CURL=‘curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Sat 19 Jun 2021 10:21:38 AM UTC] d=‘mydomain.com’
[Sat 19 Jun 2021 10:21:38 AM UTC] Getting webroot for domain=‘mydomain.com’
[Sat 19 Jun 2021 10:21:38 AM UTC] _w=’/home/mydomain.com/public_html’
[Sat 19 Jun 2021 10:21:38 AM UTC] _currentRoot=’/home/mydomain.com/public_html’
[Sat 19 Jun 2021 10:21:38 AM UTC] entry=‘“type”:“http-01”,“url”:“https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g",“status”:“pending”,“token”:"5OJUE01o6y6rDjmvnpQqukz-FejfbUwiM9ZJi2QWrqw”’
[Sat 19 Jun 2021 10:21:38 AM UTC] token=‘5OJUE01o6y6rDjmvnpQqukz-FejfbUwiM9ZJi2QWrqw’
[Sat 19 Jun 2021 10:21:38 AM UTC] uri=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:38 AM UTC] keyauthorization=‘5OJUE01o6y6rDjmvnpQqukz-FejfbUwiM9ZJi2QWrqw.jE4EEpKm6i6CvtqVUakHb7Q_zc4BrNz5jdqTZXbNhNE’
[Sat 19 Jun 2021 10:21:38 AM UTC] dvlist=‘mydomain.com#5OJUE01o6y6rDjmvnpQqukz-FejfbUwiM9ZJi2QWrqw.jE4EEpKm6i6CvtqVUakHb7Q_zc4BrNz5jdqTZXbNhNE#https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g#http-01#/home/islamicgr>
[Sat 19 Jun 2021 10:21:38 AM UTC] d=‘www.mydomain.com’
[Sat 19 Jun 2021 10:21:38 AM UTC] Getting webroot for domain=‘www.mydomain.com’
[Sat 19 Jun 2021 10:21:38 AM UTC] _currentRoot=‘/home/mydomain.com/public_html’
[Sat 19 Jun 2021 10:21:39 AM UTC] entry=‘“type”:“http-01”,“url”:“https://acme.zerossl.com/v2/DV90/chall/FlFOL7uSai_uoK1449TjfA",“status”:“pending”,“token”:"CJ6u7cfOq8t2tEaRhNJeswLp3pxWNbzUbYcK8yYEKig”’
[Sat 19 Jun 2021 10:21:39 AM UTC] token=‘CJ6u7cfOq8t2tEaRhNJeswLp3pxWNbzUbYcK8yYEKig’
[Sat 19 Jun 2021 10:21:39 AM UTC] uri=‘https://acme.zerossl.com/v2/DV90/chall/FlFOL7uSai_uoK1449TjfA’
[Sat 19 Jun 2021 10:21:39 AM UTC] keyauthorization=‘CJ6u7cfOq8t2tEaRhNJeswLp3pxWNbzUbYcK8yYEKig.jE4EEpKm6i6CvtqVUakHb7Q_zc4BrNz5jdqTZXbNhNE’
[Sat 19 Jun 2021 10:21:39 AM UTC] dvlist=‘www.mydomain.com#CJ6u7cfOq8t2tEaRhNJeswLp3pxWNbzUbYcK8yYEKig.jE4EEpKm6i6CvtqVUakHb7Q_zc4BrNz5jdqTZXbNhNE#https://acme.zerossl.com/v2/DV90/chall/FlFOL7uSai_uoK1449TjfA#http-01#/home/islam>
[Sat 19 Jun 2021 10:21:39 AM UTC] vlist=‘mydomain.com#5OJUE01o6y6rDjmvnpQqukz-FejfbUwiM9ZJi2QWrqw.jE4EEpKm6i6CvtqVUakHb7Q_zc4BrNz5jdqTZXbNhNE#https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g#http-01#/home/islamicgre>
[Sat 19 Jun 2021 10:21:39 AM UTC] d=‘mydomain.com’
[Sat 19 Jun 2021 10:21:39 AM UTC] d=‘www.mydomain.com’
[Sat 19 Jun 2021 10:21:39 AM UTC] ok, let’s start to verify
[Sat 19 Jun 2021 10:21:39 AM UTC] Verifying: mydomain.com
[Sat 19 Jun 2021 10:21:39 AM UTC] keyauthorization=‘5OJUE01o6y6rDjmvnpQqukz-FejfbUwiM9ZJi2QWrqw.jE4EEpKm6i6CvtqVUakHb7Q_zc4BrNz5jdqTZXbNhNE’
[Sat 19 Jun 2021 10:21:39 AM UTC] uri=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:39 AM UTC] _currentRoot=’/home/mydomain.com/public_html’
[Sat 19 Jun 2021 10:21:39 AM UTC] wellknown_path=‘/home/mydomain.com/public_html/.well-known/acme-challenge’
[Sat 19 Jun 2021 10:21:39 AM UTC] writing token:5OJUE01o6y6rDjmvnpQqukz-FejfbUwiM9ZJi2QWrqw to /home/mydomain.com/public_html/.well-known/acme-challenge/5OJUE01o6y6rDjmvnpQqukz-FejfbUwiM9ZJi2QWrqw
[Sat 19 Jun 2021 10:21:39 AM UTC] Changing owner/group of .well-known to islam8210:nogroup
[Sat 19 Jun 2021 10:21:39 AM UTC] url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:39 AM UTC] payload=‘{}’
[Sat 19 Jun 2021 10:21:39 AM UTC] POST
[Sat 19 Jun 2021 10:21:39 AM UTC] _post_url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:39 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Sat 19 Jun 2021 10:21:39 AM UTC] _ret=‘0’
[Sat 19 Jun 2021 10:21:39 AM UTC] code=‘200’
[Sat 19 Jun 2021 10:21:39 AM UTC] trigger validation code: 200
[Sat 19 Jun 2021 10:21:39 AM UTC] sleep 2 secs to verify
[Sat 19 Jun 2021 10:21:41 AM UTC] checking
[Sat 19 Jun 2021 10:21:41 AM UTC] url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:41 AM UTC] payload
[Sat 19 Jun 2021 10:21:41 AM UTC] POST
[Sat 19 Jun 2021 10:21:41 AM UTC] _post_url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:41 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Sat 19 Jun 2021 10:21:42 AM UTC] _ret=‘0’
[Sat 19 Jun 2021 10:21:42 AM UTC] code=‘200’
[Sat 19 Jun 2021 10:21:42 AM UTC] Processing
[Sat 19 Jun 2021 10:21:42 AM UTC] sleep 2 secs to verify
[Sat 19 Jun 2021 10:21:44 AM UTC] checking
[Sat 19 Jun 2021 10:21:44 AM UTC] url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:44 AM UTC] payload
[Sat 19 Jun 2021 10:21:44 AM UTC] POST
[Sat 19 Jun 2021 10:21:44 AM UTC] _post_url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:44 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Sat 19 Jun 2021 10:21:45 AM UTC] _ret=‘0’
[Sat 19 Jun 2021 10:21:45 AM UTC] code=‘200’
[Sat 19 Jun 2021 10:21:45 AM UTC] Processing
[Sat 19 Jun 2021 10:21:45 AM UTC] sleep 2 secs to verify
[Sat 19 Jun 2021 10:21:47 AM UTC] checking
[Sat 19 Jun 2021 10:21:47 AM UTC] url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:47 AM UTC] payload
[Sat 19 Jun 2021 10:21:47 AM UTC] POST
[Sat 19 Jun 2021 10:21:47 AM UTC] _post_url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:47 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Sat 19 Jun 2021 10:21:47 AM UTC] _ret=‘0’
[Sat 19 Jun 2021 10:21:47 AM UTC] code=‘200’
[Sat 19 Jun 2021 10:21:47 AM UTC] Processing
[Sat 19 Jun 2021 10:21:47 AM UTC] sleep 2 secs to verify
[Sat 19 Jun 2021 10:21:49 AM UTC] checking
[Sat 19 Jun 2021 10:21:49 AM UTC] url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:49 AM UTC] payload
[Sat 19 Jun 2021 10:21:49 AM UTC] POST
[Sat 19 Jun 2021 10:21:49 AM UTC] _post_url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:49 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Sat 19 Jun 2021 10:21:50 AM UTC] _ret=‘0’
[Sat 19 Jun 2021 10:21:50 AM UTC] code=‘200’
[Sat 19 Jun 2021 10:21:50 AM UTC] Processing
[Sat 19 Jun 2021 10:21:50 AM UTC] sleep 2 secs to verify
[Sat 19 Jun 2021 10:21:52 AM UTC] checking
[Sat 19 Jun 2021 10:21:52 AM UTC] url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:52 AM UTC] payload
[Sat 19 Jun 2021 10:21:52 AM UTC] POST
[Sat 19 Jun 2021 10:21:52 AM UTC] _post_url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:52 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Sat 19 Jun 2021 10:21:52 AM UTC] _ret=‘0’
[Sat 19 Jun 2021 10:21:52 AM UTC] code=‘200’
[Sat 19 Jun 2021 10:21:52 AM UTC] Processing
[Sat 19 Jun 2021 10:21:52 AM UTC] sleep 2 secs to verify
[Sat 19 Jun 2021 10:21:54 AM UTC] checking
[Sat 19 Jun 2021 10:21:54 AM UTC] url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:54 AM UTC] payload
[Sat 19 Jun 2021 10:21:54 AM UTC] POST
[Sat 19 Jun 2021 10:21:54 AM UTC] _post_url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:54 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g ’
[Sat 19 Jun 2021 10:21:55 AM UTC] _ret=‘0’
[Sat 19 Jun 2021 10:21:55 AM UTC] code=‘200’
[Sat 19 Jun 2021 10:21:55 AM UTC] Processing
[Sat 19 Jun 2021 10:21:55 AM UTC] sleep 2 secs to verify
[Sat 19 Jun 2021 10:21:57 AM UTC] checking
[Sat 19 Jun 2021 10:21:57 AM UTC] url=‘https://acme.zerossl.com/v2/DV90/chall/WGfVdrVRoH_aLO3e-_nK4g’
[Sat 19 Jun 2021 10:21:57 AM UTC] payload
[Sat 19 Jun 2021 10:21:57 AM UTC] POST
[Sat 19 Jun 2021 10:21:57 AM UTC] Diagnosis versions:
openssl:openssl
OpenSSL 1.1.1f 31 Mar 2020
apache:
apache doesn’t exist.
nginx:
nginx doesn’t exist.
socat:
socat by Gerhard Rieger and contributors - see www.dest-unreach.org
socat version 1.7.3.3 on Oct 26 2019 17:42:04
running on Linux version #80-Ubuntu SMP Mon Apr 12 17:35:00 UTC 2021, release 5.4.0-72-generic, machine x86_64
features:
#define WITH_STDIO 1
#define WITH_FDNUM 1
#define WITH_FILE 1
#define WITH_CREAT 1
#define WITH_GOPEN 1
#define WITH_TERMIOS 1
#define WITH_PIPE 1
#define WITH_UNIX 1
#define WITH_ABSTRACT_UNIXSOCKET 1
#define WITH_IP4 1
#define WITH_IP6 1
#define WITH_RAWIP 1
#define WITH_GENERICSOCKET 1
#define WITH_INTERFACE 1
#define WITH_TCP 1
#define WITH_UDP 1
#define WITH_SCTP 1
#define WITH_LISTEN 1
#define WITH_SOCKS4 1
#define WITH_SOCKS4A 1
#define WITH_PROXY 1
#define WITH_SYSTEM 1
#define WITH_EXEC 1
#undef WITH_READLINE
#define WITH_TUN 1
#define WITH_PTY 1
#define WITH_OPENSSL 1
#undef WITH_FIPS
#define WITH_LIBWRAP 1
#define WITH_SYCLS 1
#define WITH_FILAN 1
#define WITH_RETRY 1
#define WITH_MSGLEVEL 0 /debug/
km
kmpmba #2
Seemed like a DNS issue, resolved after a few hours of retry
pb
pb007 #3
I had a similar issue today. I solved mine by running “wget -O - https://get.acme.sh | sh” then try to issue the cert again. something to do having an older version of acme. “ERROR: certbot 0.21.1 has requirement acme==0.21.1, but you’ll have acme 1.9.0 which is incompatible.”
