2FA Problem
as
alireza_salehi #1
2FA Enabled automatically!!! and even admin cannot login lo admin panel,
Google Authenticator
how to disable 2FA???
ar
ardan7779 #2
I have same issue. I Stuck in login form and always says " Invalid verification code." but I sure, I have input the code correctly many times.
Please help…
LP
LPackman #4
Please help…
I was experiencing the same. Did you check your system time?
timedatectl
bg
bgxerjoe #6
its just clear your cache browser … its happen to high security user if you open in 2 different browser
AO
Adeosun Ojo Abiodun #7
Time appears to be a major factor for this error. I got mine fixed by synching the time of Google Authenticator. Go to the settings then click ‘Time correction for codes’ . You can then sync the time on your authenticator. This helps solve the issue i have. I believe it will work for others too.
al
alkama #8
that isnt working pls can you help
Aa
Aamir #9
Could Not Login, Error message: Invalid verification code.
