Problem after update to Cyberpanel 2.0.3
jw
jwgoogle #1
I just upgraded a server to cyberpanel 2.0.3. The upgrade script did not run smoothly. The mariadb service failed to start and more. We manually installed and retsarted the maridb service.
When I visit the cyberpanel UI on port: 8090 and try to login, I get these error message:
Could Not Login, Error message: (1054, “Unknown column
‘loginSystem_administrator.twoFA’ in ‘field list’”)
Screenshot: Awesome Screenshot
I cannot login to Cyberpanel now which is a big problem.
Any advice welcome.
jw
jwgoogle #2
Yes. I edited the upgrade script to remove the mariadb section then ran the upgrade. It completed successfully and seems to have solved the login problem.
kw
kwave #3
@jwgoogle How did you edit the upgrade script to remove Mariadb. I am having same issue.
jw
jwgoogle #4
There is a section that starts with text:
[mariadb]
Simply edit the script using a text editor and remove the entire section.
ge
getfreephoto3377 #5
Can’t access my login page of cyberpanel (:8090) after updating to 2.0.3 and also not working your login button. i waste my 2 days in this problem. please check this bug cybepanel team.
