Help Getting SSL Cert To Work On Hostname/Cyberpanel Control Panel URL
Ei
Eisenheim #1
Hi there
Hoping someone can help me with this.
I am using my registrars nameservers. I have A Records set up at my register for my CyberPanel VPS’ nameservers (NS1.mydomain.com / NS1.mydomain.com). All domains work fine and all SSL certs are working on all domains fine other than my hostname.
I was having some problems getting the sub-domain/hostname I created to access Cyberpanel working, so created an A Record at my registrar (A Record = control.mydomain.com pointed to server IP).
This fixed the access problem and I can access Cyberpanel via control.mydomain.com perfectly now.
I have applied SSL to Hostname as per Cyberpanel instructions but it doesn’t appear to apply the cert as I am getting Connection Not Secure when I access Cyberpanel.
Is there something more I need to add at my registrar for Letsencrypt to recognise the cert I am issuing via Cyberpanel?
Thanks!
ia
ianw5555 #2
I take it you have created subdomain control.mydomain.com and gave it lets encrypt cert for CP to use?
