[HELP] Error 500 - CyberPanel
Jo
Jorge #1
Hello, Someone could help me, what should I do to solve the problem?
My system:
Ubuntu 18.04 (Vm Google)
Last version of CyberPanel
Previous action, a few days ago, I updated the version of MariaDb with the following guidelines:
And all OK
After several days (Today), current state of the system: All websites run smoothly, but when I try to access the control panel I get an error 500
Action: After searching in this forum and in google I tried to update again.
Terminal results
Processing /usr/local/pip-packs/mysqlclient-1.4.6.tar.gz
command: /usr/local/CyberPanel/bin/python3 -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-req-build-g6ewntl0/setup.py’“'”‘; file=’“'”‘/tmp/pip-req-build-g6ewntl0/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r
‘"’“');f.close();exec(compile(code, file, '”‘“‘exec’”’“‘))’ egg_info --egg-base /tmp/pip-pip-egg-info-g3cjyckf
cwd: /tmp/pip-req-build-g6ewntl0/
Complete output (12 lines):
/bin/sh: 1: mysql_config: not found
/bin/sh: 1: mariadb_config: not found
File “”, line 1, in
File “/tmp/pip-req-build-g6ewntl0/setup.py”, line 16, in
metadata, options = get_config()
File “/tmp/pip-req-build-g6ewntl0/setup_posix.py”, line 61, in get_config
libs = mysql_config(“libs”)
File “/tmp/pip-req-build-g6ewntl0/setup_posix.py”, line 29, in mysql_config
raise EnvironmentError(”%s not found" % (_mysql_config_path,))
OSError: mysql_config not found
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
command failed, exiting…
Thank you very much.
wh
whattheserver #2
would have to see it firsthand via ssh
possible your missing some packages from looking up that error.
Jo
Jorge #3
Hello Whattheserver, thanks for your help.
In the end solve the installation process by launching the following command before launching the installation.
apt install default-libmysqlclient-dev
after the installation process finished, and I can access the control panel without error 500, although I saw that there was a problem with some dependencies.
I have mounted another VM with another Cyberpanel image to migrate the sites as I don’t trust the stability.
Thanks for your quick help, it helped me to detect the problem and apply the solution.
A greeting.
