Scheduled Incremental Backup Problems
tr
trustedwebdesign #1
Hi, not sure if anyone able to advise. Having problems with scheduled incremental backups. Manual incremental backups are fine. Did have a time sync issue, but this is sorted.
Was able to find log in /home/cyberpanel/incbackuplogs which reports a “Fatal: unable to open config file: Stat: The difference between the request time and the current time is too large.” Also getting “Failed backup for xyzdomain.com error: Will first initiate backup repo…”
Tried the obvious, made sure no s3 bucket exists, times synced and match aws perfectly. This is on v2. Also had problem on 1.9.4, never had scheduled backups working.
Regards David
tr
trustedwebdesign #2
Ok, so I’ve just gone into the buckets and the backups are now there! Maybe its fixed, I’ll keep and an eye on it.
