Cron jobs not running
LP
LPackman #1
For the past few days, I have been trying to get WPALLImport cron jobs to run via Cyberpanel cron job manager.
System:
Hosting: Hostinger VPS | 4 vCPU |
4 GB RAM | 80GB SSD
OS: Ubuntu 18.04.4 LTS
Cyberpanel: v 2.0
Php: 7.3
Redis installed: Yes
Memcache installed: Yes
CSF: Enabled
Example cron which I added to Cyberpanel cron manager:
wget -q -O - http://example.co.uk/wp-load.php?import_key=examplekey&import_id=335&action=trigger >/dev/null 2>&1
I have a sneaky suspicion it is not running due to special characters such as “&” but I really have no idea!
In CSF live sytem log I noticed
Suspicious Process PID:30010 PPID:28935 User:furxxxx Uptime:89 secs EXE:/usr/local/lsws/lsphp74/bin/lsphp CMD:wget -q -O - http://example.co.uk/wp-load.php?import_key=examplekey&import_id=335&action=trigger >/dev/null 2>&1
So I added the following line to csf.pignore which seems to have stopped the alert displaying in the CSF system live log
cmd:wget -q -O - http://example.co.uk/wp-load.php?import_key=examplekey&import_id=335&action=trigger >/dev/null 2>&1
Can anyone shed some light on why the cron is not working please and any steps to resolve.
I am new to VPS however I have already searched the forum, found many cron related posts however nothing seems to be working for me.
Thank you :slight_smile:
LP
LPackman #2
Thank you for that,
Followed your advice, I finally managed to get the cron to run with php command /php-cgi
td
tdwuk #3
could you elaborate on that please?
ca
call2kay #4
Hey How did you fixed that? Can you write it here please?
Ay
Aydin #7
I fixed the issue in a better way.
if this happens to you probably two things causing the error. the ‘&’ symbol or SSL error that prevents the trigger.
What I did was I redirected yourdomainadress/trigger/ and yourdomainadress/processing/ to cron links.
I used Redirection plugin but you can do this with any other plugin or via htaccess
and lastly below commands need to be added in cyberpanel;
wget --spider “yourdomain.com --no-check-certificate
now it should work like a charm.
Al
Alisson #8
No need to add >/dev/null 2>&1 ?
ge
geimsdin #9
With --spider no need to add >/dev/null…
