Closed help! 403 Forbidden
an
anisur #1
403
Forbidden
Access to this resource on the server is denied!
I am getting this error after using 1 click wordpress installation.
Plz check inmarking. Com for error.
Be
BenStill #2
I have same issue (
he
henscu #3
I have the same problem ie ‘403 Forbidden’ page after WordPress+LSCache install from CyberPanel 1.9.4.
Is there a solution yet, or should I just use PHP 7.3 instead of 7.4?
By the way, what is the simplest way to delete the failed PHP 7.4 WordPress install so that I can reinstall it again on PHP 7.3 (is it even necessary to do this)? Can I just delete the WordPress home directory from command line in Ubuntu using the command: deluser --remove-home my-wp-user
Bi
Bipul #4
Try PHP 7.3 instead of 7.4. this will solve the problem.
bl
blue928 #5
Is this still an issue in 3/2021 I’m getting the same problem. PHP 7.4 is installed by default. Why would one need to downgrade to get this to work?
al
alboz #6
Same problem! my wp installation won’t work on php8 nor php7.4 - Only 7.3
what’s wrong?
bi
biguenique #8
I had the same problem (403) with a single WordPress site with a custom Child Domain that was moved in a WordPress Multisite environment. The other custom domains worked fine, but I had to switch this domain domain to PHP 7.3 to make this specific site work.
After deactivation a few useless/misconfigured/old plugins, I was able to switch the Child Domain back to PHP 7.4 or 8.0. I’m not sure which one was the exact culprit.
us
usmannasir #9
Check your LiteSpeed error logs to see what is causing the issue.
th
threplogle #10
I realize this is an older thread but I just had the same problem with the single click install. Apparently it doesn’t create the database properly. To fix, you need to create a database () and then edit your wp_config file and add the database name, username, & password using file manager.
fl
fluxx #11
change group to nogroup and user wht ever website user is for public_html folder
