Help setting up DNS
ma
maxvoggel #1
Hello all,
I am struggling to get my DNS configuration working properly. This is where I am at.
Namecheap Glue Records for domain maxvogel.com are set:
ns1.cloud.maxvogel.com → 174.138.52.42
ns2.cloud.maxvogel.com → 174.138.52.42
Namecheap is still pointing to my Cloudflare Nameservers which resolve my other records. The following records are currently set in Cloudflare:
A ns1.cloud.maxvogel.com → 174.138.52.42
A ns2.cloud.maxvogel.com → 174.138.52.42
I simply added a test subdomain (test.maxvogel.com) to Cloudflare:
NS test.maxvogel.com → ns1.cloud.maxvogel.com
NS test.maxvogel.com → ns2.cloud.maxvogel.com
I have “successfully” created the nameservers in CyberPanel. When I add a zone for the test domain (test.maxvogel.com). I am unable to add any records.
I would appreciate the community’s thoughts, suggestions, and knowledge.
Thanks,
Max :slight_smile:
sl
slowaways #2
If you can change the port from 8090 to 8443 you can setup CloudFlare with CyberPanel!
hi
hieu #3
May I ask how can I change the port from 8090 to 8443?
