WHMCS session problem
ha
hasarinda #1
How to fix this ? I used PhP 7.3 this folder /var/lib/lsphp/session 777 but error not fixed
PHP Session Support
PHP session support is enabled.
Session autostart is disabled.
The PHP session save path /var/lib/lsphp/session is not writable. Please investigate the session.save_path PHP setting or contact your system administrator
fu
fungal #2
Did you make it recursive (so the PHP version folder would also be writable as mine mentioned the version folder also)? I have the same issue and was just starting to fiddle with it.
sh
shoaibkk #3
gave the session path to tmp and try
ra
ranojit #4
How? I tried but it won’t work.
