Issue with python MarkupSafe module on install
ne
netbos #1
Provider: Virtual Machine under VMWare Workstation 15
Virtualization Type: VMWare
System: Centos 7.7 & Ubuntu 18.04
Installation option:
OLS or Enterprise?
OLS
official
N/A
Install LiteSpeed Memcached?
N/A
Install Memcached?
N/A
N/A
Install Redis?
N/A
Problem:
When I try to install CyberPanel under VMWare minimal CentOS 7 or Ubuntu 18.04 basic server, install fails. On CentOS 7 it show following error message
 command: /usr/local/CyberPanel/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-fg156h2x/MarkupSafe/setup.py'"'"'; __file__='"'"'/tmp/pip-install-fg156h2x/MarkupSafe/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\\r\
‘"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ egg_info --egg-base /tmp/pip-install-fg156h2x/MarkupSafe/pip-egg-info
cwd: /tmp/pip-install-fg156h2x/MarkupSafe/
Complete output (5 lines):
File “”, line 1, in
File “/tmp/pip-install-fg156h2x/MarkupSafe/setup.py”, line 3, in
from setuptools import setup, Extension, Feature
ImportError: cannot import name ‘Feature’
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
command failed, exiting…
I tried re-install on clean Ubuntu 18.04 VM but same issue occurred
I don’t think this is caused by VMWare enviroment but I might be wrong.
ne
netbos #2
Soon after I’ve posted this someone else also encountered same issue.
ne
netbos #3
I’ve tried to increase MarkupSafe module version in requirements.txt one at the time.
When I’ve got to 0.19 command /usr/local/CyberPanel/bin/pip3 install --ignore-installed -r requirements.txt completes successfully.
sp
spyderweb #4
I am guessing the script could be uploaded with a bug, I am going to try a mirror
qt
qtwrk #5
fixed , please try again
ma
manoj80in #6
File “install.py”, line 2388, in
main()
File “install.py”, line 2342, in main
checks.installAcme()
File “install.py”, line 2197, in installAcme
preFlightsChecks.call(command, self.distro, command, command, 1, 0, os.EX_OSERR)
File “install.py”, line 207, in call
res = subprocess.call(shlex.split(command))
File “/usr/lib64/python3.6/subprocess.py”, line 287, in call
with Popen(*popenargs, **kwargs) as p:
File “/usr/lib64/python3.6/subprocess.py”, line 729, in init
restore_signals, start_new_session)
File “/usr/lib64/python3.6/subprocess.py”, line 1364, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: ‘/root/.acme.sh/acme.sh’: ‘/root/.acme.sh/acme.sh’
Oops, something went wrong…
