Editor Issue - 'utf8' codec can't decode byte 0xa9 in position 4919: invalid start byte
w3
w3services #1
‘utf8’ codec can’t decode byte 0xa9 in position 4919: invalid start byte
Whenever we try to edit file online. Sometimes working sometimes not.
Also, the edit window can be bigger or full screen will help to work fast.
jo
jobayer #2
make sure you have selected only the file which you want to edit. i have faced same issue due to selecting multiple files at a time or selecting folder. the color of selected file is not deep, its light thus we select new file but still old file remain selected without knowing.
w3
w3services #3
Still no luck. something else creating an issue.
Cy
CyberPanel #4
What kind of file is this? Content of file? What happens if you cat this file from terminal?
w3
w3services #5
Its a simple Html file. When I download and edit and upload it works but online edit not working.
st
stecko #6
I have the same error when install/start docker onlyoffice/communityserver
