Installation 503 Problem
Co
CodingGuys #1
Provider: Digital Ocean
Virtualization Type: Droplet
System: CentOS 8.1x64 1vcpu 2GB 50GB
Installation option: Install CyberPanel
OLS or Enterprise?
Enterprise
official
yes
Install LiteSpeed Memcached?
yes
Install Memcached?
yes
yes
Install Redis?
yes
Problem:
Followed the installation guide. Installed LiteSpeed Server Enterprise using valid serial number. Installs. When I try to go to login - ServerIP:8090 I’m getting a 503 Service Unavailable The server is temporarily busy, try again later!
I’ve checked to see if LSCPD is running using - systemctl status lscpd which is showing as active.
Also tried the steps in Manually set up virtualenv but to no avail.
Co
CodingGuys #2
Further to my initial bug report. When carrying out the steps in Manually Set up virtualenv I get the following:
virtualenv --system-site-packages /usr/local/CyberCP results in
Using base prefix ‘/usr’
No LICENSE.txt / LICENSE found in source
New python executable in /usr/local/CyberCP/bin/python3.6
Not overwriting existing python script /usr/local/CyberCP/bin/python (you must use /usr/local/CyberCP/bin/python3.6)
File “/usr/local/bin/virtualenv”, line 11, in
sys.exit(main())
File “/usr/local/lib/python3.6/site-packages/virtualenv.py”, line 870, in main
symlink=options.symlink,
File “/usr/local/lib/python3.6/site-packages/virtualenv.py”, line 1162, in create_environment
install_python(home_dir, lib_dir, inc_dir, bin_dir, site_packages=site_packages, clear=clear, symlink=symlink)
File “/usr/local/lib/python3.6/site-packages/virtualenv.py”, line 1691, in install_python
raise e
File “/usr/local/lib/python3.6/site-packages/virtualenv.py”, line 1683, in install_python
proc = subprocess.Popen(cmd, stdout=subprocess.PIPE)
File “/usr/lib64/python3.6/subprocess.py”, line 729, in init
restore_signals, start_new_session)
File “/usr/lib64/python3.6/subprocess.py”, line 1364, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
OSError: [Errno 40] Too many levels of symbolic links: ‘/usr/local/CyberCP/bin/python3.6’
Then when I try: systemctl restart gunicorn.socket I get
Failed to restart gunicorn.socket: Unit gunicorn.socket not found.
Co
CodingGuys #3
Hi thanks for replying.
I’m using Digital Ocean and created the following:
CentOS 8.1 x64
1 VCPU 2GB RAM 50GB Space
Co
CodingGuys #4
If I type in my Droplet IP I get the LiteSpeed Congratulations page but only over http not https://
if I try and add 8090 I get the 503 page
ba
bangden #5
It is recommended for Centos 7.x
