How to Speed up Websites
Ra
Rahul #1
Hello all
How can speed up WordPress websites on a dedicated server?
Before my website was hosted on Cpanel + Litespeed that time rocking speed well on my all sites
But when i migrate to cyberpanel then all sites slow
I tested gtmetrix showing page speed F
I installed cyberpanel with redis + Opcache also and i increased PHP memory limit also but still slow
I use LiteSpeed cache plugin + Wpfaster cache also
My server config
Dual E5-2620 v3 - 24Cores
42GB Ram
600GB SSD
1Gbps
Anyone, please advise me kindly i was suffering from this
sp
splaquet #2
I have a dedicated box with comparable server specs, running about 6 HEAVY websites. I have load times of less than 1sec (typically .2-.4 sec).
My assumption would be that the LiteSpeed Cache plugin isn’t optimized for your needs.
You’ve left out a few essential details. Most importantly, is your website news/blog/ecommerce/etc ? If so, you need to ensure that you have ESI enabled and entirely setup/configured.
Additionally, (assuming that you have a sitemap.xml generated) have you added your sitemap URL to the crawler? I’ve seen poor results when there isn’t a sitemap… so, while I’m not 100% certain on how everything works in the LiteSpeed cache plugin, I can say that this part is VERY essential.
Also, ensure that you’re connected to quick.cloud in General settings. If you don’t, you’re not going to see a lot of optimizations that you would/could benefit from.
…in summary, I can say that with a server like yours, it really should not be the server slowing your site down.
Ra
Rahul #3
I tried everything still slow i going back to Cpanel.
Ra
Rahul #4
Still running out of this issue no one idea :roll_eyes:
Ma
Marcelo #5
Change some configurations in Litespeed
Server Configuration > Tuning
Connection
Max Connections 30000
Max SSL Connections 20000
Connection Timeout (secs) 300
Max Keep-Alive Requests 10000
Keep-Alive Timeout (secs) 5
Send Buffer Size (bytes) 0
Receive Buffer Size (bytes) 0
Server Configuration > Security
CGI Settings
CGI Daemon Socket Not Set
Max CGI Instances 30 - best cpu
Minimum UID 11
Minimum GID 10
Force GID Not Set
umask Not Set
CGI Priority 0
CPU Soft Limit (sec) 10
CPU Hard Limit (sec) 50
Memory Soft Limit (bytes) 0
Memory Hard Limit (bytes) 1800M
Process Soft Limit 400
Process Hard Limit 450
cgroups Disabled
Per Client Throttling
Static Requests/second 500
Dynamic Requests/second 350
Outbound Bandwidth (bytes/sec) 0
Inbound Bandwidth (bytes/sec) 0
Connection Soft Limit 30
Connection Hard Limit 50
Block Bad Request Yes
Grace Period (sec) 15
Banned Period (sec) 60
LS reCAPTCHA - Protect from attacks
Enable reCAPTCHA Yes
Site Key Not Set
Secret Key Not Set
reCAPTCHA Type Checkbox
Max Tries Not Set
Allowed Robot Hits 200 fixing a limit
Bot White List Create a List
Connection Limit 3000
SSL Connection Limit 2000
Server Configuration > External App
Environment |PHP_LSAPI_CHILDREN=200
LSAPI_AVOID_FORK=1|
Max Connections |200|
Max Idle Time|86400|
Memory Soft Limit (bytes)|0|
Memory Hard Limit (bytes)|3048M|
Process Soft Limit |0 - from server default
Process Hard Limit |2800| max of server
More in Dedicated with Large Site | Tuning Guide | LiteSpeed Web Server | LiteSpeed Documentation
