Changing ssh port breaks web terminal
ik
ikk157 #1
I recently changed the ssh port, but as soon as I did so, that broke the web terminal. It shows error connecting to backend.
Any clue on how i can updates the new port on the web terminal?
ve
veriloji #2
Change file; /usr/local/CyberCP/WebTerminal/CPWebSocket.py
self.sshclient.connect(‘127.0.0.1’, 22, username=‘root’, pkey=k)
replace port 22 here
then restart the ssh server and kill CPWeb process
ps aux | grep CPWeb
kill -9 pid number
ik
ikk157 #3
@veriloji said:
ps aux | grep CPWeb
kill -9 pid number
Did that to no avail. The issue persists.
ik
ikk157 #4
I forgot to mention that i also disabled the root user. Could that also contribute to the issue?
ve
veriloji #5
Yes,
I haven’t tried, but change root in this file.
self.sshclient.connect ( ‘127.0.0.1’, 22, username = ‘root’, pkey = k)
ik
ikk157 #6
@veriloji said:
Yes,
I’ve already tried that too, along with the new port. Same issue.
ve
veriloji #7
I don’t know root account, i haven’t tried
But my server is work to different port.
ik
ikk157 #8
Weird
Cy
CyberPanel #9
I will detect SSH port from ssh configuration file, will produce a fix soon.
ik
ikk157 #12
@CyberPanel said:
I fixed the issue when port other then 22 is used → Bug fix: detect non-default SSH port for WebTerminal · usmannasir/cyberpanel@54f83c3 · GitHub
You can get the fix using new upgrade guide → 02 - Upgrading CyberPanel - 01 - Install/Upgrade - CyberPanel Community
You will also have to restart SSH web server.
I updated, but it still doesn’t work. However, when i re-enabled the root user from cyberpanel itself, the web terminal started working. However, as soon as I disable the root user (again, from cyberpanel itself), the web terminal stops working again.
Can you look into this too please?
ik
ikk157 #13
Anyone?
ik
ikk157 #14
Not sure why my issue keep going unnoticed. Am I doing something wrong?
Wr
Wraith #15
Hi, got still same problem after upgrade, please help!
Cy
CyberPanel #17
Are you using hostname SSL? Terminal won’t work without valid hostname SSL.
na
naszprezes #19
Oh, i think it should be noticed somewhere on screen, should not be? Thanks!
de
deep123 #20
can not connect using ssh…
