Please help docker image volume mapping doesn't work
im
imran_mohd87 #1
Hello I want to install zammad helpdesk and in thier documentation they use docker compose . I have installed docker compose and successfully cloned the git repository. My question is in cyberpanel nextcloud docker tutorial it says to map volume with website path which we created inside cyberpanel like /home/example.com how do I specify this in docker compose yml ? This the file I need to edit and it has multiple volume for multiple containers do I need to change all the volumes to my website path? And how do I map port and reverse proxy ?? Where do I write the rewrite rules?? Please help I am stuck it’s for my production server
La
LarryR #3
imran - did you stay with cyberpanel?
i’d also like to get that help-desk to work in a production environment on cyberpanel
Pi
Pimmal #4
You can not do that with cyberpanel, you need to do this over commandline, as far as i know docker compose administration is not part of cyberpanel.
