How to write translation for CyberPanel
Cy
CyberPanel #1
Hello
To write translation for CyberPanel, you can download the language file from: https://raw.githubusercontent.com/usmannasir/cyberpanel/1.8.0/locale/br/LC_MESSAGES/django.po
msgid "Create Cloud Linux Package - CyberPanel"
msgstr "Add your translated text here"
Using this method replace all msgstr with your translated text. Once the file is completed, you can either create a pull request on Github, or email your translated file to support[at]cyberpanel.net. Make sure to include the name of the language you have translated to.
Thanks.
Ne
Nencio #2
Hi
I have added updated Polish translation on github.
To
ToledoUUYio #4
The CyberPanel One-Click Image is a next-generation hosting control panel, language and type in your username and password to log in to CyberPanel
Ro
Rome6ro #5
Please add a Polish language to the project, because I do not have any rights to the project on github.
Go
Gonzalez #6
Using this method replaces all msgstr with your translated text. Once the file is completed, you can either create a pull request on Github or email your translated file to support[at]cyberpanel.net. Make sure to include the name of the language you have translated to.
da
dampel #8
This manual is deprecated. Where is English is this folder ?
/usr/local/CyberCP/locale
I’m modify my language file, but after saving and restarting the server there are no changes in the interface
