Hostname SSL Not Working? Or Am I doing it wrong?
sa
saiftheboss7 #1
Installed Cyberpanel fresh. Everything is working and I can access the panel via IP:8090.
Also, I added A record from Cloudflare to my server IP for mywebsite.com.
I wanted to access the panel via hostname. So I created a new website as panel.mywebsite.com first. Then issued SSL for hostname for the same domain panel.mywebsite.com - everything worked.
Restarted Litespeed too. Now when I go to panel.mywebsite.com I can see the OpenLiteSpeed page but panel.mywebsite.com:8090 returns nothing.
sa
saiftheboss7 #4
no. I am okay if I can access the panel using panel.mywebsite.com:8090 - but unfortunately that’s not working too! I can only access using the IP
Cy
CyberPanel #5
You need to turn of CloudFlare proxy for panel subdomain, it won’t allow port 8090.
ki
kingkongnewmedia #8
I am locked out from CyberPanel - OMG !!!
  1. I issue an sslForHostName
  2. My domain is on Cloudflare
  3. When I access the IP:8090 It not working same for the domain:8090
WHAT TO DO?
HF
Harry F #9
Thanks, this worked!
zk
zkhseo #10
I face the same problem too.
HL
HLT #11
You’ll need to modify the panel’s prot to access Cloudflare’s supported ports
For example: 443|2053|2083|2087|2096|8443
Let’s assume that it is: 2083
Then you can access the https://panel.example.com:2083
