1.8.6 update after 8090 port not working, How to fix, Help me Please ?
fa
fatihyasar #1
1.8.6 update after 8090 port not working, 1.8.5 version downgraded. pyhton update.py starting error;
[root@localhost ~]# python upgrade.py
File “upgrade.py”, line 8, in
django.setup()
File “/usr/lib64/python2.7/site-packages/django/init.py”, line 27, in setup
apps.populate(settings.INSTALLED_APPS)
File “/usr/lib64/python2.7/site-packages/django/apps/registry.py”, line 85, in populate
app_config = AppConfig.create(entry)
File “/usr/lib64/python2.7/site-packages/django/apps/config.py”, line 94, in create
module = import_module(entry)
File “/usr/lib64/python2.7/importlib/init.py”, line 37, in import_module
import(name)
ImportError: No module named CLManager
Cy
CyberPanel #2
cd /usr/local
wget https://cyberpanel.net/CyberPanel.1.8.6.tar.gz
tar -zxf CyberPanel.1.8.6.tar.gz
cp settings.py CyberCP/CyberCP/
rm upgrade.py
wget https://cyberpanel.net/upgrade.py
python upgrade.py
re
rebnaque #3
hi look to see if you can use the zip file of the module called CLManager, go to “/ usr / local / CyberCP” then use the command python upgrade.py again CLManager.zip - Google Drive
yy
yyetisen #4
``` cd /usr/local wget https://cyberpanel.net/CyberPanel.1.8.6.tar.gz tar -zxf CyberPanel.1.8.6.tar.gz cp settings.py CyberCP/CyberCP/ rm upgrade.py wget https://cyberpanel.net/upgrade.py python upgrade.py
</blockquote>
<blockquote class="Quote" rel="rebnaque">hi look to see if you can use the zip file of the module called CLManager, go to "/ usr / local / CyberCP" then use the command python upgrade.py again https://drive.google.com/open?id=1v_NLRc2q-AM99z-unCyNgAWiEYLDvD7W</blockquote>
error upgrade;
  File "upgrade.py", line 1654, in <module>
    main()
  File "upgrade.py", line 1650, in main
    Upgrade.upgrade()
  File "upgrade.py", line 1574, in upgrade
  File "/usr/lib64/python2.7/site-packages/django/db/models/manager.py", line 85, in manager_method
  File "/usr/lib64/python2.7/site-packages/django/db/models/query.py", line 373, in get
    num = len(clone)
  File "/usr/lib64/python2.7/site-packages/django/db/models/query.py", line 232, in __len__
    self._fetch_all()
  File "/usr/lib64/python2.7/site-packages/django/db/models/query.py", line 1102, in _fetch_all
  File "/usr/lib64/python2.7/site-packages/django/db/models/query.py", line 53, in __iter__
  File "/usr/lib64/python2.7/site-packages/django/db/models/sql/compiler.py", line 863, in execute_sql
    sql, params = self.as_sql()
  File "/usr/lib64/python2.7/site-packages/django/db/models/sql/compiler.py", line 420, in as_sql
  File "/usr/lib64/python2.7/site-packages/django/db/models/sql/compiler.py", line 373, in compile
  File "/usr/lib64/python2.7/site-packages/django/db/models/sql/where.py", line 79, in as_sql
  File "/usr/lib64/python2.7/site-packages/django/db/models/lookups.py", line 169, in as_sql
  File "/usr/lib64/python2.7/site-packages/django/db/models/lookups.py", line 162, in process_lhs
  File "/usr/lib64/python2.7/site-packages/django/db/models/fields/__init__.py", line 640, in db_type
  File "/usr/lib64/python2.7/site-packages/django/utils/functional.py", line 35, in __get__
    res = instance.__dict__[self.name] = self.func(instance)
  File "/usr/lib64/python2.7/site-packages/django/db/backends/mysql/base.py", line 174, in data_types
  File "/usr/lib64/python2.7/site-packages/django/db/backends/mysql/features.py", line 53, in supports_microsecond_precision
  File "/usr/lib64/python2.7/site-packages/django/db/backends/mysql/base.py", line 385, in mysql_version
  File "/usr/lib64/python2.7/contextlib.py", line 17, in __enter__
    return self.gen.next()
  File "/usr/lib64/python2.7/site-packages/django/db/backends/base/base.py", line 591, in temporary_connection
    cursor = self.cursor()
  File "/usr/lib64/python2.7/site-packages/django/db/backends/base/base.py", line 254, in cursor
    return self._cursor()
  File "/usr/lib64/python2.7/site-packages/django/db/backends/base/base.py", line 229, in _cursor
    self.ensure_connection()
  File "/usr/lib64/python2.7/site-packages/django/db/backends/base/base.py", line 213, in ensure_connection
    self.connect()
  File "/usr/lib64/python2.7/site-packages/django/db/utils.py", line 94, in __exit__
    self.connect()
  File "/usr/lib64/python2.7/site-packages/django/db/backends/base/base.py", line 189, in connect
  File "/usr/lib64/python2.7/site-packages/django/db/backends/mysql/base.py", line 274, in get_new_connection
  File "/usr/lib64/python2.7/site-packages/MySQLdb/__init__.py", line 81, in Connect
  File "/usr/lib64/python2.7/site-packages/MySQLdb/connections.py", line 193, in __init__
    super(Connection, self).__init__(*args, **kwargs2)
django.db.utils.OperationalError: (2003, 'Can\\'t connect to MySQL server on \\'127.0.0.1\\' (111 "Connection refused")')
